Stocker Build Help
Stocker Build Help
This is a discussion on Stocker Build Help within the CRF50 forums, part of the General Talk category; So I am building my stocker motor up in a sense and need some input/advice...heres what ive got stock head but will be ported and ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
    trtr013's Avatar
    Jan 2009
    Beaverton, OR
    stock head but will be ported and polished
    Powroll hi comp 39mm piston(13:1)
    TB race cam for stock head(idk if I will use it though its just collecting dust so i wonder if itd work)
    Yosh TRS pipe
    Uni air filter but stock carb
    1. Should I use the stock cam or tb cam?
    2. Stock carb will still work? What jetting should I use?
    is If you're not first, you're
    last
    crf50kid309's Avatar
    Feb 2010
    moorpark CA
    i think portin and polishing stock head on a stock motor would make it so there isnt any power i think i read something like taht on here
    trtr013's Avatar
    Jan 2009
    Beaverton, OR
    that makes no sense tho all your doing is allowing more air flow in and out and when accompanied with a high comp piston and an exhaust and whatnot it should help a lot i would think. I will ask some engine builders and see
    AngryDirtbikers17's Avatar
    Aug 2008
    NH
    use the cam...get the stock carb ported as well
    trtr013's Avatar
    Jan 2009
    Beaverton, OR
    u mean the intake only right? so just use a stock carb? im wondering what jets to use or where to start even...i bought a tb cam so hopefully mike can answer me
    Aug 2008
    NH
    this is what you need. cuz the carb is gonna restrict alot of power
    http://planetminis.com/community/top...egas-mod-carb/
    get that ported and the intake matched .
    Im not sure on jetting tho
    trtr013's Avatar
    Jan 2009
    Beaverton, OR
    sounds good thats what ill do...its not for vegas or any racing just for the hell of it kinda thing i did. goes on my stunt bike no racing but buddy has an 88 and i dont wanna put an 88 on my bike. Mike said to put the cam in but I need to make sure the valves wont hit the piston dome.
    chrisc161076's Avatar
    Jun 2006
    Wales
    Quote Originally Posted by trtr013 View Post
    Yosh TRS pipe
    I used to run the 15:1 powroll, and l didn't feel a difference on my arse dyno, so l sold it and went back to stock and sold the expensive powroll piston.
    The TB cam is good and cheap, takegawa better and Crower better again
    Yoshi pipe to big for 50cc, mod your stock pipe and invest somewhere else.
    Uni filter helps with stock carb, but a 17mm carb makes a big difference
    Takegawa 3sp gears makes a massive difference and you'll have change left over from your pipe
    Get the pro pack of poweroll washers to let your clutch engage at higher rpm.
    Porting your head will also help.
    Have a look at your gearing aswell to suit your ride area.
  10. #9
    Bulldog88's Avatar
    Jan 2011
    Kodiak, Alaska
    Yosh TRS pipe
    I interested in seeing if the TB race cam for stock head would work also. I have one laying around and im going to try it out in my wifes 50. Would this make more power? Ive heard that you would get some better low end but you would lose your top end speed, is this true?
  11. #10
    is a slow rider on a fast bike
    solidjohnny's Avatar
    Nov 2007
    Honolulu, Hawaii
    the TB cam makes a very noticeable difference on the mid-top end, and you can't really tell the difference on the low-end. I am running stock carb,jet, and pipe. My spark plug reads fine. Just install the cam and piston and turn the engine over by hand to see if anything touches. I'm pretty sure the cam makes more of a difference than the piston.
    You should also do the IRK or ORK. I have the cheap china IRK and it made the engine a good bit more responsive, and its still running perfect. I'm almost certain that the Pitster Pro daytona style ORK will work on the stock honda motor as well.
  12. #11
    trtr013's Avatar
    Jan 2009
    Beaverton, OR
    Nah the yosh pipe is the way to go i love that thing. Im going to port the head, intake and carb. I have a kitaco IRK lying around but every engine builder i talked to said dont run it if Im not racing it. Besides dirt still scares the crap outta me lol... Johnny this thing is seriously a fricken money pit. Thankfully i find great deals on parts. I was going to put the IRK and other parts on the 124 build but since the cases cracked idk maybe I will toss the IRK on the stock motor. If not i got a takegawa 88 motor on the shelf that i may put it in. IDK the tb cam may go in either motor IDK yet...
  13. #12
    Nov 2007
    Honolulu, Hawaii
    did they give you a reason why you wouldn't wanna run the IRK? A track opened right next to my shop a few weeks ago so i think all we're gonna be doing is racing dirt. Neither of my bikes have any stunt parts on them anymore. Although I'm thinking about having a motard set for my modded 50 just to see what kind of stoppies I can do. My 600RR and 450X haven't been ridden in months. My gixxer has been in pieces in my garage for like 3 years....
  14. #13
    trtr013's Avatar
    Jan 2009
    Beaverton, OR
    didnt know u had a 600rr...your poor 450 and i didnt know u still had ur gixxer...i got my fiddy and idk to go to a track its so far away. Im thinkn of having a setup for dirt just to ride on trails and the track if we ever go but always will keep the stunt stuff. I just started ridding fiddy again last week for first time in 2 yrs but no big bikes in like 2.5yrs but mainly havent ridden since my 954 in hawaii i miss that bike...
    back to topic though. Now i have to run 108 race fuel it says for the new piston kit. I just didnt wanna run the IRK cause it makes the bike rev much faster and then i lose all bottom end and torque that i want. Thats the reason ive always kept my stock flywheel.
    got any stunt parts or stock cylinder, rear wheel for a fiddy?
  15. #14
    Towlieee's Avatar
    Feb 2007
    Quote Originally Posted by solidjohnny View Post
    IRK kit gives less engine braking, and makes the bike more twitchy which makes stunting a little harder.
    I still stunt with my stage 3 88cc honda trail bikes setup with a IRK kit and 4 speed, but it makes it harder for my friends to control, and make some tricks a little harder.
    Going to a 108cc now so that'll be a new thrill for stunting lol
  16. #15
    is Mooie compounds 2016 edit
    LongMooie's Avatar
    Jun 2005
    originaly UK! now Central valley, Cali
    50cc tuning is all top end they dont have the torque to pull so its needs to be kept in the higher rpm range when racing
    every mod you do will be top end power
    high lift cam
    bigger carb
    hi comp piston
    head porting/polishing
    your street riding and you need torque to pull the front up from a low rpm range
    your waisting your money unless you race 50cc class, keep it 50cc but somewhat stock for smooth power for stunt riding
    stock exhaust is proven to be best for 50cc
3sp vs 4 speed
