Inner Rotor Kit help
This is a discussion on Inner Rotor Kit help within the CRF50 forums, part of the General Talk category; After replacing damaged parts on a 50 with TB 117cc kit(#6) the mechanic is telling us we need to replace inner rotor kit too. It ...
Results 1 to 8 of 8
    GSH_456's Avatar
    May 2012
    VA
    After replacing damaged parts on a 50 with TB 117cc kit(#6) the mechanic is telling us we need to replace inner rotor kit too. It seems these things have a bad reputation for being unreliable. Trying to find out which one's are top notch is making me dizzy! Any help is appreciated.
    deuce808's Avatar
    Aug 2008
    dont bother with a inner rotar kit if you dont have the tb billet clutch basket upgrade or youll destroy clutches as well as the rotar. you can get the Tak IRK which is built completely different from any other brand (the kitaco is built like the chinese ones) but it costs $500+. if you want to run a IRK i have 2 (one used, one brand new) that ill sell for $50+ shipping. check out Tbolt for the clutch basket upgrade and Minimob for the Tak IRK
    GSH_456's Avatar
    May 2012
    VA
    Thank you for the help, I appreciate it. I have a Kitaco inbound. Also am upgrading with TB billet housing upgrade. Hopefully the clutch will last awhile! Thanks again.
    TenFiddy's Avatar
    May 2012
    Kitaco IRK sucks!
    JohnnyB's Avatar
    Nov 2003
    CT
    I've been run KITACO inner rotors on 2 of my race 50's and another on my race KLX 110's and just bought one for my newest KLX race bike build ... They've all been trouble free to date .., knock on wood .. .... One of the 50 rotor kits has been go'n strong since 2004 ..
    Just say'n ....
    GSH_456's Avatar
    May 2012
    VA
    Newest problem award goes to the timing chain tensioner spring. The timing chain has too much play. Is there a stronger after market spring available? Bought the bike already stroked to 108. After it blew up we upgraded it to 117. Not sure if the cylinder is 63mm or 69mm. Mechanic suggested I find an after market spring. Is there such a thing?
  7. #7
    taz69's Avatar
    Nov 2005
    Nope no aftermarket spring.. But they do make 2 different cam chains for the 50.. One is stock length for the 63mm cylinder and the other is for the 69mm cylinder.. IF your guide wheel on the cam chain tensioner arm goes out or gets real worn it will act like the cam chain is to long. There located behind the round cover behind the IRK... I always stretch my cam chain springs out just a little to get a little more tension but the arm could be all the way down and the roller that goes on the cam chain could be worn out..
  8. #8
    GSH_456's Avatar
    May 2012
    VA
    Thanks for the help Taz
  1. Crf50 klx110 reeg inner rotor weights for kitaco or the china rotor kits
    By p3racer in forum CRF50/CRF70 Parts For Sale
    Last Post: 03-21-2012, 08:12 PM
  2. Kitaco Inner Rotor Vs. China Ebay Inner Rotor
    By compoundridersinc in forum KLX110, DRZ110, TTR90
    Last Post: 12-19-2010, 12:09 PM
  3. 210-220mm front rotor, billet rotor adaptor rear.
    By PowerFiend in forum Vendor Area - Wanted
    Last Post: 03-31-2009, 11:56 PM
  4. Replies: 14
    Last Post: 11-27-2008, 07:09 AM
  5. Outer rotor vs. Inner rotor ignition?
    By frdvschvy in forum CRF50
    Last Post: 03-22-2005, 09:35 PM
cr50 inter rotor ebay
how to do timing on inner rotor kit
how to replace the rotor on a honda xr50
how to time inner rotor kit crf50
inner rotor kit bad for crf50?
inner rotor kit parts
inner rotor kit timing
klx 110 put inter rotor kit in time
klx110 inner rotor kit
klx110 stock inner rotor kit
stroker kit inner rotor kit crf50
what goes bad inner rotor kit
