I need help!!
This is a discussion on I need help!! within the CRF50 forums, part of the General Talk category; i have no earthly idea what kind of frame is in my crf 50 it works with the bbr superpro big bike style swingarm and ...
Results 1 to 6 of 6
Thread: I need help!!
    d-4 kid's Avatar
    Jun 2010
    jacksboro tx
    I need help!!
    i have no earthly idea what kind of frame is in my crf 50 it works with the bbr superpro big bike style swingarm and bbr sp-5 forks its all aluminim and its longer than stock bit i cant find any sort of identification on it about the brand of it
    Rankin141's Avatar
    Jun 2010
    Chula Vista, CA
    Not sure on the brand, but that swingarm/shock/frame combo is not correct.
    d-4 kid's Avatar
    Jun 2010
    jacksboro tx
    not correct for the frame? different shock you would recomend?, to make the ride higth taller?
    is excited to test the big valve
    50cc ripper motor
    LongMooie's Avatar
    Jun 2005
    originaly UK! now Central valley, Cali
    i think thats a chinese frame ive seen frames like that on ebay, they are made to fit the stock Aframe swingarms and shock to match Aframed swingarms
    your need to relocate the shock mount and a longer shock to get the bike to sit correct, down side is once you weld aluminum you need to have it heat treated
    or it will be very fragile
    d-4 kid's Avatar
    Jun 2010
    jacksboro tx
    its not made for the aframe style bacause the shock mont would be way higher up on the frame if it wasnt
    50cc ripper motor
    LongMooie's Avatar
    Jun 2005
    maybe the swingarm that originally came with that frame had a higher mounting point on the swingarm, i have seen some like that its kinda like a block that sticks up where as the shock goes down into the BBR swingarm
super pro swingarm stock crf 50
