to big valve or not to big valve my +R head
This is a discussion on to big valve or not to big valve my +R head within the CRF50 forums, part of the General Talk category; Naturally its my decision to make in the end. Just wanted some outside opinions cause 99% of the work I do is high performance based ...
View Poll Results: to BV or not to BV that is thy question
- Voters
- 13. You may not vote on this poll
factory size valves
big valve that biotch!
Naturally its my decision to make in the end. Just wanted some outside opinions cause 99% of the work I do is high performance based and the more hp that can be provided within the allotted budget the happier the guy/gal is. With this build the g/f is unsure if she wants more powe cause she don't understand what it will do. When I try to explain i apparently am to technical in my explanation. From what I see of her riding I feel she could use it. And again cause ur prolly thinking then y the hell did u start this poll. Well I wanted to get some outside views what u guys would if u were in my position. Just so we are clear I wasn't burnt a smart ass when I said bigger valves would make more within the curtain. Alot of guys think big valves always = more top end. Was just simply elaborating that you can oversize valves and make more bottom and mod if setup properly. So if u took offense to my post please don't it wasn't meant as anything other tha you can oversize the valves and maintain the bottom end it has or make it better as well as opkther protiona in the curven
07-10-2012 09:59 AM
LOL wasnt thinking that! but sometimes I and up answering my own questions in the transmission busniess.I like youre post.
Come on, lets get this going again. Id like to know more about this combo.
well poll is almost over and looks like majority votes go to BV this puppy
. so that is what imma gonna do. thank you to everyone that placed votes.
i didn't give much details about everything cause the engine is being stuffed in a honda trx 90 and this is a crf 50 section and i didn't want to hear some smartass tell me you know this is a crf 50 section. but since i have sparked an interest for a few i'll give details and post the progress of it on here.
chassis as stated already is a trx 90 that has been widened and long travel suspension on it.
prior engine setup
-takie +r head w/ 35 cam and my port work
-keihin 22 or 24mm carb
- trx 90 bottom end was used and only thing done to it was heavy clutch springs
- 54mm tb piston
- lifan OR ignition
- and light bore pro circuit exhaust
- 54mm x 49.5mm puts cc at 113.37cc
New engine setup
-bore will get upped to 57mm i'm going to use a tb 57mm piston simply cause its cheap and easy/quick to get. it is going to require me to do some flycutting to the valve notches. but i'm going to oversize the valves so more than likely i would had to oversize valve notches any how and w/ the stroker crank i'll have to take a lil off timing edge to establish the deck height i want.
-stroke will be upped to 57mm also. i will use a takie 54mm offset stroke to 57mm
-carb will be either a pe 28 or pwk 28 not sure which one i will use. it will depend what tuning length i can get w/ manifold in the trx chassis
-will still use the lifan OR
-will get a CR 4 speed trans
-will get a manuel clutch
-head will get a full over haul. new guides, oversize seats, oversized valves to 30/24, valve springs i'm not sure if i'll change yet or not. once i check seating and nose pressures i'll make that decision
-exhaust will eventually get change haven't decided if i wanna build a custom tuned exhaust for it or take the easy route out and just pick up a chp
-i'm going to try the s35 cam for now simply cause i sold all my other cams for this head.
i think its about time she learnt to ride a proper bike and get rid of the quad
CRF150Rb will do nicely
Originally Posted by
LongMooie
lol i have tried her and 2 wheels go together like oil and water.
storminnorman07
Remember how well a water pump can mix oil and water when a seal fails and make milky white water oil.
Damn dude, you really dont mess around. That is SWEET !!!
Hey Chad where did you get that cylinder?
taz69
That's a resleeve I have done. But I believe shark is the companies name that has them already done.
storminnorman07
The bigger valves will make more hp within the curtain over the factory 28.5/23.5 setup. When I get off work ill check and see if I still have any dynos of factory sized valves to oversized valves.
got any for the 106 +R im sure i need new piston and rings in my +R, how much would a valve job be?
Storminnorman07. Nice work! I'm happy to see your educated and resourced well. (tooling) I too have done simular motors and I lol'ed a few times while reading your posts. I just finished up a project where i stuffed the intake port to increase the velocity for a change in power delivery. Most people here don't have the background we have and I find it challenging to educate people on physics 101 every time I suggest a pipe or carb size. And omg I'll never comment on a "race fuel" thread ever again! lol. Anyway it's nice to know there are others alike on PM and it's not all 15 year olds talking nonsense.
I see your from PA too! Do any big bike Moto in D6?
LongMooie
sorry don't have any 106 R pistons. wish i did this really could use the 106 57mm scut +R piston. i thought the Tb would work out nice but...not so much, intake top ring land is real thin. valve job 60 bucks plus the ride home.
Jordo
thanx jordo. as with any forums you gotta pick and choose when you discuss and when to just leave it be. lol dont forget we too were once knuckle head 15 year olds thinking we knew everything and had engine building by the horns
i haven't raced since 2003 and even then i was a atv racer. never was one for the 2 wheel scene until i rode a pitbike. these sketchy lil fockers are so much fun to ride.
she fired up on the first pull now the fun begins of putting plastics all back on and tuning it in
So what piston did you endup going with or what did you have to end up doing to that TB piston to get it to work with the +R head Chad??? Thanks..
taz69
Depends what's ur definition of work..lol its in there piston and valve clearance on intake side is slim to none. So one hick up and this bad boy will be a paper weight. Im just going to run it until I can get a piston in for it.
- You may not post replies
- You may not edit your posts
Forum Rules
By storminnorman07 in forum Import/Chinese Parts for Sale
Last Post: 07-16-2008, 12:23 PM
By team505 in forum CRF50/CRF70 Parts For Sale
Last Post: 12-19-2006, 01:40 PM
By storminnorman07 in forum CRF50
Last Post: 12-03-2006, 11:27 AM
By mattv in forum CRF50/CRF70 Parts For Sale
Last Post: 05-01-2006, 07:22 PM
By thorwarrior915 in forum CRF50
Last Post: 01-06-2006, 10:34 PM
cc'ing combustion takegawa
chp carb trx90
crf50 big valve head
crf50 custom head
crf50 stock valves
high hp crf50 on a budget
how to port a trx 90 head
option 1 head big valve
piston 54mm daytona
stock valve vs big valve
takegawa s cut piston chamber
the valve no enter in the guide valve in my honda trx
