need help. chain rubbing on swingarm
This is a discussion on need help. chain rubbing on swingarm within the CRF50 forums, part of the General Talk category; I got a plus 5 inch a frame swing arm and my chain rubs on swingarm during bumps or jumping. Need some ideas on how ...
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By ride171
  • 1 Post By doja.release
Thread: need help. chain rubbing on swingarm
    ride171's Avatar
    May 2013
    I got a plus 5 inch a frame swing arm and my chain rubs on swingarm during bumps or jumping. Need some ideas on how to fix itClick image for larger version.
ID:	116943Click image for larger version.
ID:	116944Click image for larger version.
    is RACING
    PocketBikeRacingTsmmr's Avatar
    Mar 2011
    NJ
    Sorry I'm looking at the pictures from my phone .
    Is the chain rubbing up against where you are pushing it into with your fingers?
    If that :
    Was going to say add a chain roller but that doesn't look to be the issue .
    Other thrn doing somd swing arm cutting and modding ..The only way I figure to get the chain further away from the swing in that part is to maybe add a washer to the sprocket side of the axle between the spacer and frame .
    MINI RACING @
    Hidden Content
    NJminiGP kidz at New Jersey Motorsports Park
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    is RACING
    Mar 2011
    NJ
    Can you post a picture of that side of the bike so I can see how the chains running off the front sprocket to the rear .
    MINI RACING @
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    is BRAAAP!
    Frank21x's Avatar
    Mar 2009
    Lodi, California
    is that a two bros/billetware swinger?
    ride171's Avatar
    May 2013
    Yea its were my finger is pushing it. If i thighten the chain enough it wont hit but then its way to tight. I was thinking about using the spacers but will that effect the bike if the wheel is favoring one side. That pic wont help prob but i dont have any of the other side currently
    is RACING
    Mar 2011
    NJ
    Really nice bike..
    Maybe there is a way to add a thin Delrin plate to that area of the swing arm to protect the swing arm from the chain rubbing on it...but you'd have to make sure the chain would not get snagged on it when the swing up compressed etc..
    Is there such a thing as a slightly offset rear Sprocket?...Maybe a rear sprocket the gets the chain slightly closer to the wheel..
    Otherwise I'd try one washer to that side just to see if it makes it better..
    MINI RACING @
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    doja.release's Avatar
    Aug 2012
    You could certainly get a pice of cutting board, file a couple notched in it and zip tie it to the swinger as a makeshift slider. Have done it with good results and if you do it nice it looks good as well.
    What gearing are you running? Another, probably better but more costly option would be to go to a smaller rear sprocket. If you go down 3 teeth in the rear and one in the front then your gearing will be virtually the same.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Is it possible that you have the wheel spacers on the wrong sides of the wheel?
    - dirtbkr188 -
  10. #9
    ride171's Avatar
    May 2013
    I like the cutting board idea. Im thinking its the chain. The chain is stretched bad and real sloppy side to side. I have a new chain coming so ill go from there. Thanks for all the help and suggestions guys.
  11. #10
    is RACING
    Mar 2011
    NJ
    Quote Originally Posted by ride171 View Post
    I was going to say,maybe your chains worn out...
    Make sure to lube your chain well..
    Not sure how you lube your chain but :seems when I use certain lubes they thicken up on the chain and I get slop..
    Now I know you have to clean,lube your chain ,just saying that a good stick on lube may prevent 'some of the future hitting of the chain on the swingarm
    MINI RACING @
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
  12. #11
    Banned
    1badklx707's Avatar
    Jun 2013
    I have the same swing arm. I cant see the pics but do you have a chain guard on it? Mine was rubbing untill I replaced it with a factory one
  1. Chain Rubbing With Bigger Shock!! Help Please
    By madeinuk132 in forum KLX110, DRZ110, TTR90
    Last Post: 05-10-2011, 07:20 PM
  2. Cam chain Rubbing ????
    By Crfmxking in forum CRF50
    Last Post: 10-24-2009, 12:09 PM
  3. Chain rubbing on swingarm
    By theduck007 in forum Chinese/Import Minis - General Discussion
    Last Post: 06-16-2009, 11:40 PM
  4. I-Shock Chain Rubbing
    By punkguitarist in forum KLX110, DRZ110, TTR90
    Last Post: 02-02-2008, 01:46 PM
  5. Cam chain tightness/rubbing on glide plates?
    By 06klx110 in forum KLX110, DRZ110, TTR90
    Last Post: 01-21-2006, 12:30 AM
cam chain rubbing
chain rubbing on frame with swingarm extension
chain rubs on swingarm ttr 90
crf50 chain hitting case
crf50 chain rubbing
extended swingarm chain hits frame
how to get my chain unstuck from between the swing arm and sprocket
how to keep your chain from rubbing the case on a crf50
how to protect swinging arm from the chain
preventing chain rubbing swing arm
ttr 90 chain rubs on swingarm
why is my chain hitting my swing arm on bike that's stretch 12 inches
