***88cc kit stock carb***
This is a discussion on ***88cc kit stock carb*** within the CRF50 forums, part of the General Talk category; I bought a bike that has bbr 88cc kit and has the stock carb...seems to run fine ..is it ok to run that carb or ...
Results 1 to 12 of 12
    mopark310's Avatar
    Jul 2013
    I bought a bike that has bbr 88cc kit and has the stock carb...seems to run fine ..is it ok to run that carb or should i go bigger ?? Thanks
    Ruckus420's Avatar
    Sep 2014
    Maine,USA
    I'm putting and 88cc kit on my crf50, and I'm going to be running stock crab and pipe. Every one has been telling it's just fine to run stock carb
    is Tinkering
    mrrcx's Avatar
    Jun 2011
    Westlake Village, CA
    It depends on the cylinder head. the stock head should get the stock carb, a race head should get a larger carb
    DSR BLACK DEATH's Avatar
    Feb 2006
    South texas
    Check your plug and see if it needs a re jetting.
    But if it runs fine & you want low end, stock works
    Hidden Content Toooooo many mini bikes
    84z50, 91z50r, 95z50r, 91 & 99z50r apart, xr50, 2-xr70s, 03xr100, 08 hayabusa
    1999 & 2000 Jincheng Pandas stock n street legal....
    2 - 2013 skyteam flashback Red & black
    2-71 ct70s
    BCM
    BCM is offline
    BCM's Avatar
    Jul 2014
    Rocklin Ca.
    It's fine, I have bikes with just a 88cc cylinder kit with stock head and stock carb, and I have a complete 88cc kit with a super head and over sized carb, not a big difference
    mopark310's Avatar
    Jul 2013
    Ok just checking plug looks good..,i didnt know if it had some more power in it by putting bigger carb or not...i believe its stock head also thanks for the help guys
    Darrie's Avatar
    Aug 2010
    Cairns, Far North Queensland, Up Top Down Under
    I run same 88 cc stock carb setup, but the next OEM mainjet up (which is 2 up on the OEM jet number). Std aircleaner and with exhaust baffle in & the plug colour is a nice brown - so its well matched.
    I'm surprised the super head doesn't far outrev the std 88cc - the whole point of this setup is a much higher revving motor that delivers torque much further into the rev range. Does it deliver power at higher RPM ?
    2 sons that ride highly modified 2001 XR50 and 1997 Z50R
    hyperichie's Avatar
    Dec 2016
    Virginia
    I have a UNI air filter on my OEM carb with 88cc kit. Have a bog at WOT and a little bit of back fire issue. I am thinking go to a #60 main jet and buy a adjustable needle? Your thoughts?
    Thank You & Merry Christmas,
  10. #9
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Does it backfire on accel or on decel? Backfire on accel is rich, backfire on decel is lean
    - dirtbkr188 -
  11. #10
    hyperichie's Avatar
    Dec 2016
    Virginia
    back fire on decel after I rev it up high. I think the UNI filter might be the issue. Do you recommend buying a #60 MJ and adjustable needle? Idle seems rough too almost like timing is off
    Thanks
  12. #11
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Yes, I suggested that in your other post, along with drilling out the air screw plug if you have one.
    - dirtbkr188 -
  13. #12
    hyperichie's Avatar
    Dec 2016
    Virginia
    I have already drilled out plug and have access to screw. I will order MJ from Local dealer and see if I can get my hands on an adjustable needle.
  1. Replies: 4
    Last Post: 06-13-2012, 03:34 AM
  2. Stock Carb Jet Size for 88cc?
    By *kingpin* in forum CRF50
    Last Post: 03-16-2010, 03:21 PM
  3. TB 88cc bore, stock carb,pipe,head. what jets?
    By Mcduuuugal in forum CRF50
    Last Post: 06-03-2009, 06:08 AM
  4. 88cc stock carb?
    By jblair117 in forum Honda CRF70
    Last Post: 04-07-2009, 01:44 PM
  5. Looking for a tb 88cc carb
    By fiddie deep in forum Bikes and Parts Wanted - All Makes
    Last Post: 02-22-2009, 08:21 PM
