Need help for jetting stock carb with 88 big bore
This is a discussion on Need help for jetting stock carb with 88 big bore within the CRF50 forums, part of the General Talk category; Hi. Not new in the honda's game got bikes since almost 20 years but , ive never modify a 50's . I would like to ...
Results 1 to 6 of 6
    TangsHonda's Avatar
    Aug 2016
    Hi. Not new in the honda's game got bikes since almost 20 years but , ive never modify a 50's . I would like to know wich main jet and the pilot jet to put in a stock carb for a 88 big bore , i got a uni air filter and a full exhaust system on it to as well but no cam or a ported head thanks a lot for your help really appreciated
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    A #60 or #62 main jet. The pilot jet is a non-removable pilot jet tube.
    - dirtbkr188 -
    hyperichie's Avatar
    Dec 2016
    Virginia
    This is my 3rd Fiddy but after many years I have been out of the game. Just picked up a 05 CRF that has been sitting. It has an 88cc Takagawa with stock carb with Uni Foam Filter. I finally got her running but she bogs at WOT and pops off a couple back fires. Air Filter is clean and recently oiled. Do I need to buy a #60 main jet and adjustable needle? Any additional info would be great appreciated! MERRY CHRISTMAS!!
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You can try the #60 main jet, and it sounds like you might want to drill out the air screw plug if you have one, so you can adjust the air screw. Wouldn't be a bad idea to get the adjustable jet needle as well.
    - dirtbkr188 -
    hyperichie's Avatar
    Dec 2016
    Virginia
    Where can I buy a #60 MJ for oem carb and adjustable needle? Bike Bandit.com?
    Thank you!
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Any Honda Dealer can order it for you, here is the OEM part number for a 2002 XR50 jet needle kit, the needle has 5 grooves for adjustment - 16012-GEL-701.
    The #60 main jet you may have to get from JetsRus, they are right here
    - dirtbkr188 -
  1. TB big bore kit with stock carb?
    By bossman in forum CRF50
    Last Post: 01-22-2015, 06:55 PM
  2. Big Bore Kit with stock carb?
    By xplo40 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-11-2009, 10:45 PM
  3. Stock Bore TTR125LE 24mm carb jetting
    By veedub in forum Bigger Minis Forum
    Last Post: 02-24-2007, 01:51 PM
  4. Stock bore 110 big carb question??
    By filthyboatguy in forum KLX110, DRZ110, TTR90
    Last Post: 01-18-2007, 02:13 PM
  5. running a big bore kit with stock carb and filter
    By bennian in forum KLX110, DRZ110, TTR90
    Last Post: 04-17-2006, 05:35 PM
