Using crf50 drum with 70 hub
This is a discussion on Using crf50 drum with 70 hub within the CRF50 forums, part of the General Talk category; I have a crf50 five-0 swingarm and trying to fit a set of 70 wheels to it. Will the 50 drum work in the 70 ...
Results 1 to 5 of 5
    back_it_in's Avatar
    Dec 2015
    I have a crf50 five-0 swingarm and trying to fit a set of 70 wheels to it. Will the 50 drum work in the 70 hubs to give me correct wheel spacing? Are the axles different diameters? Anyway to make it work if not?
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    The axles for the 50 and the 70 are both 12mm, and the 50 brake panels will not work with the 70 wheel hubs, they are smaller and a different design. Have you tried the 70 rear wheel and brake panel for fitment to your swingarm? If anything, you may have to move the brake panel tab forward on the swingarm.
    - dirtbkr188 -
    back_it_in's Avatar
    Dec 2015
    Yeah I tried the 70 wheel and the spacer was way too long. Bought a 50 spacer thinking that might solve it but only cut the distance in half. Brake tab not an issue, will work fine
    back_it_in's Avatar
    Dec 2015
    I'm just so lost, I want the damn swingarm to work lol
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Is it possible to machine some material from the end of the brake panel to give you more room on the sprocket side for the 50 spacer, and still not throw off the inline alignment of the chain between the front and back sprocket?
    - dirtbkr188 -
  1. WTB-CRF50 rear drum hub w/ hd spokes and quality rim
    By wisco in forum Bikes and Parts Wanted - All Makes
    Last Post: 07-22-2013, 05:23 PM
  2. CRF50 rear hub OEM drum or aftermarket
    By Glasshouse in forum Bikes and Parts Wanted - All Makes
    Last Post: 09-02-2009, 02:09 AM
  3. I need used klx110 hub and drum brake
    By T-rav in forum KLX110, DRZ110, TTR90
    Last Post: 05-23-2007, 07:10 PM
  4. Billet drum hub blowout!!! $99 and less??
    By ~E in forum CRF50/CRF70 Parts For Sale
    Last Post: 12-03-2006, 08:07 PM
  5. LOOKING FOR **stock hub and drum brake**
    By princessSDM in forum CRF50/CRF70 Parts For Sale
    Last Post: 10-28-2006, 02:07 AM
