BBR Super Pro Frame - What steering stem bearings?
This is a discussion on BBR Super Pro Frame - What steering stem bearings? within the CRF50 forums, part of the General Talk category; Hey man I have a question.. Hopefully you can answer it for me. I just bought a crf50 with the bbr super pro frame/swingarm. It ...
Results 1 to 2 of 2
    Mister motard's Avatar
    Jun 2016
    Pittsburgh pa
    Hey man I have a question.. Hopefully you can answer it for me. I just bought a crf50 with the bbr super pro frame/swingarm. It has the marzoocchi shiver forks. There is a little bit of play between the steering stem and the head of the frame. Im thinking I need new steering head bearings. The question is where and what bearings do I need? It's tough because I don't have a stock frame or stock forks. So I haven't found any info. The only steering head bearings I can find is for a crf50. I don't want to buy the wrong s**t.
    Sent from my SM-N920V using Tapatalk
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Mister Motard,
    measure the ID of the steering stem neck on the frame, and also the OD of the two areas on the steering stem where the upper and lower bearing races sit. The upper area on a 50 stem is 22.5mm and the lower area is 24mm. I have an old outer bearing race here that I can measure to let you know the ID of a stock 50 neck.
    EDIT: The OD of the outer bearing race for the 50 frame is 40.99mm
    - dirtbkr188 -
  1. steering stem dust cap for bbr frame
    By stevos50nuts in forum CRF50
    Last Post: 01-01-2010, 05:03 PM
  2. steering stem bearings
    By rlm996 in forum CRF50
    Last Post: 06-05-2008, 04:18 PM
  3. steering stem bearings
    By allmakesmx in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 02-14-2008, 11:35 AM
  4. Steering stem bearings??
    By Sideways717 in forum KLX110, DRZ110, TTR90
    Last Post: 02-09-2008, 06:34 PM
  5. Steering stem bearings?
    By Zmnypit in forum Chinese/Import Minis - General Discussion
    Last Post: 01-26-2008, 08:56 PM
