bbr handlebar kit install problem
This is a discussion on bbr handlebar kit install problem within the CRF50 forums, part of the General Talk category; just purchased bbr handle kit... bars, mount, extended cables ect... having problems with the throttle cable fitting correctly. Bike is completely stock and is band ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    just purchased bbr handle kit... bars, mount, extended cables ect... having problems with the throttle cable fitting correctly. Bike is completely stock and is band new. I have it installed in the throttle tube assembly correctly paying attention to plastic slide guide. It's almost like the throttle cable is to short. It does not fit into the carb slide correctly. Anyone ever have this problem or any ideas how to fix this....
    jamesfl's Avatar
    Dec 2016
    I find it easier to install the carb side of the cable first then connect it to the throttle and then bolt the throttle mount to the handlebars.
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    I have also tried that. The cable doesn't even go through the throttle...if I would get it on the cable on wouldnt the bike be at almost full throttle?
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    I have all the adjustment screws on the throttle cable adjusted all the way in. I can get the throttle cable on the throttle tube and carb slide but just barely. When I roll the throttle I don't have that much movement and is tight. Tied to start the bike and it idles very high. double checked everything and carb slide is installed correctly in carb. Prb going to try to give bbr a call Monday morning.....
    jamesfl's Avatar
    Dec 2016
    Keep in mind that some aftermarket throttles have a very short range of movement (can't recall what that is called). I recently installed a Protaper kit and the amount of throttle movement on the Protaper throttle is only about 1/3 of the stock.
    With that said, there should be an adjustment nut on the cable somewhere. The nut is used to adjust the cable length of the cable housing. In your case check to make sure the part the bolt screws down in is screwed all the way down. This should shorten the cable sheath length. Hope that makes sense.
    jamesfl's Avatar
    Dec 2016
    Look for something that looks like this.
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    Yes in understand the 1\4 turn throttle just feels very tight. Just doubled checked no adjustments anywhere on the cable other than the throttle screw in adjustment at the twist throttle.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Are you using the BBR throttle cable and carb cap that came with the kit, or the stock Honda throttle cable and carb cap?
    - dirtbkr188 -
  10. #9
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    Using bbr throttle cable and carb cap that came with the kit. I see the picture and I have the throttle cable adjusted all the way in. Still doesn't fit right. I also installed the throttle cable in the carb and not hooking up the throttle tube and started the bike. The engine will idle basically normal just a little low. I figured low because I don't have any tension on the throttle cable. I just don't get why the cable is so short. The part number on the cable is 510-hxr-5102
  11. #10
    dirtbkr188's Avatar
    May 2004
    New Jersey
    And you're sure the cable end at the carb cap is fully seated? When you had the cable hooked to the carb but not to the tube, did you try and pull on the cable with your fingers, to see if it was working properly?
    - dirtbkr188 -
  12. #11
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    Im pretty sure. I followed bbr directions . I would spin slid until it drops down into carb. Yes when I would pull the throttle cable with my fingers it would rev up like normal. I'm going to attempt to upload some pictures....
  13. #12
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    That's what the slide looks like with throttle tube hooked up
  14. #13
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    That's with the adjustment completely adjusted all the way in. There is no slack in throttle cable.
  15. #14
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You're aware that the beveled bottom edge of the throttle slide goes toward the back of the carb, towards the airbox end, right? Also keep in mind that the stock throttle slide is only 1-1/8" tall, and it doesn't take much to open it up to WFO.
    It looks as though you have everything assembled correctly, after you reinstall the slide into the carb throat, take a picture from the back of the carb, to see if the slide is going all the way down and bottoming out in the carb.
    - dirtbkr188 -
  16. #15
    randazzo87's Avatar
    Sep 2009
    canton,ohio
    pretty sure that's how it goes. I have the throttle cable routed left side of frame goes through factory holder and up through triple clamp. when I turn the bars side to side the rpm goes up higher. I don't have any more adjustment on throttle cable at throttle tube already maxed all the way in. (Pic a couple post above)
  1. BBR Handlebar Kit
    By tangerine in forum CRF50
    Last Post: 03-10-2010, 01:45 PM
  2. bbr handlebar kit
    By newtz in forum CRF50
    Last Post: 01-14-2008, 09:28 AM
  3. BBR handlebar kit
    By 50ryder in forum CRF50
    Last Post: 08-13-2004, 01:48 AM
  4. Is it easy to install a bbr handlebar kit
    By dannycrf in forum CRF50
    Last Post: 04-30-2004, 11:15 AM
  5. bbr handlebar kit
    Last Post: 04-27-2004, 10:00 PM
