Thank you. I just ordered them, my only other question was what about the brake lever touching the case. Do they make a pre bent one or one ready to bolt on
I just ordered a piranha 140 as well for my 50 and was wondering what jetting and carb are you running. Im trying to get some baseline jetting tips on that 22mm carb it comes with but no luck . All i find is jetting for the mikuni vm26. Sorry for hijacking your thread but some help would be appreciated..thanks.
I don't get my motor and peg mount delivered until tomorrow. so I don't know yet how that's gonna look and fit. But ill post back once i fit everything. Are you running stock jetting? I ordered a 17.5 pilot and 100-110 jets. I read somewhere that 105-107.5 is the sweetspot for the main jet.
I have a sik50s +1 brake lever and all i had to do was tap it with a rubber mallet to bend it out a lil. It hangs little low but whatever it works. I dont know if i should knotch it out.
Ideally, you would want an over-the-top brake pedal for drum brakes, but I'd be really hard pressed to tell you who makes one nowadays. If you can't rebend the stock pedal to work for you, you might have to fabricate something up on your own, using the stock pedal as a base to work from.
im still working on jetting. But damm this motor is ridiculous in this little frame.it feels like its gonna rip my arms off..It put the biggest smile on my face. So much more fun than my 88 RH. Random People walking heard my bike and couldn't believe it was this little pip squeak making all that noise.
Your bike looks sweet, did you get the carb all tuned. Are you running an ignition and key. I was using my stock harness for a cleaner look just so I could use my key but I switched it to the harness Piranha gave me.
Related Threads
2.1M posts
61.5K members
Since 2003
