Crf50 Rear Shock Spring Help
This is a discussion on Crf50 Rear Shock Spring Help within the CRF50 forums, part of the General Talk category; Can't get the damn eye piece loose, I broke 1 shock already don't wanna do it again-- does anyone know how to do this the ...
Results 1 to 7 of 7
    icexx99's Avatar
    Apr 2006
    MANALAPAN, NJ
    Can't get the damn eye piece loose, I broke 1 shock already don't wanna do it again-- does anyone know how to do this the easy way--- any tips or tricks!! The nut comes loose and I try to loosen eye piece but the shaft spins
    ryan2282's Avatar
    Jan 2005
    Lake Orion, Mi
    icexx99's Avatar
    Apr 2006
    MANALAPAN, NJ
    yeah, i used that but once i get the nut loose and try to spin off the eye the shaft moves!
    55spy's Avatar
    Mar 2006
    Omaha, Ne
    remove the bushing, heat up the eye (propane torch) don't get it so hot it melts the aluminum and it will release the locktite stuff and it will spin off. If you need hold the shaft with a pair of pliers push down the rubber stoppe and do it right below the threads. But I would just back off the jam nut until it runs out of thread and binds the shaft personally and unscrew with a mam jamma big screwdriver through the eyelet.
    152Rider's Avatar
    Apr 2006
    my buddy and i just did this with both of our 50s. take a pair of needle nose vice grips and lock them on through the spring from the side and back the lock nut all the way down. use a wrench on the nut very lightly, but it should be enough, between the two to break it free. it is much easier with two people.
    bbrcrazy's Avatar
    Sep 2005
    stick a screw driver through the eye peice and use all your strength to twist. Get a freind to hold the bolt. That is how I got mine off.
  7. #7
    icexx99's Avatar
    Apr 2006
    MANALAPAN, NJ
    yeah lol the bolt keeps coming loose though should i red loctite it let it dry and then try what you said
2006 crf50 rear spring
best crf50 rear spring
changing crf 50 shock spring
crf50 shock spring
crf50 what spring
how to change crf50 rear spring
how to remove crf50 rear spring
how to remove rear spring on xr50
how to remove sping on crf50
how to remove stock crf 50 spring
how to take back shock spring off crf50
rear shock spring change xr50
