Oil leak from exhaust port
This is a discussion on Oil leak from exhaust port within the CRF50 forums, part of the General Talk category; I put on a new(used) pipe a couple days ago and now I have oil leaking out of the exhaust port( I guess thats what ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    JD50's Avatar
    May 2004
    Lafayette, La
    I put on a new(used) pipe a couple days ago and now I have oil leaking out of the exhaust port( I guess thats what u call it...where the header meets the engine). WHATS GOING ON? Aslo, the day after I put the pipe on my bike wouldn't start...turns out the plug has no fire, wtf?
    cyclerider57
    Guest
    cyclerider57's Avatar
    Your pipe is cursed. HAHAHA
    Are you sure it is oil? There shouldn't be oil in your port. Did you replace the crush copper gasket when you put it on? Make sure your ground wire is bolted to the frame. Pull off your ignition cover and make sure the bolts are all tight.
    JD50's Avatar
    May 2004
    Lafayette, La
    Yes I'm sure its oil. Whats the crush copper gasket??
    JohnnyB's Avatar
    Nov 2003
    CT
    - Well , if you're sure it's coming from where the pipe bolts to the head , you've got big problems 8O . Time to replace the head or weld it up where it leaks from . But if it's coming from the head gasket , then you in luck .
    - The copper gasket cycle speaks of is the exhaust gasket . FYI - the OEM Honda gasket isn't made from copper
    Just say'n .... Hidden Content
    JD50's Avatar
    May 2004
    Lafayette, La
    I'm using the one that came on the pipe. Also, I have a K&N filter+the pipe so do I need to rejet?
    JohnnyB's Avatar
    Nov 2003
    CT
    Quote Originally Posted by JD50
    Usally no gasket come with pipes unless it was stuck to it and yes you'll need to rejet .
    JD50's Avatar
    May 2004
    Lafayette, La
    Ite I took the pipe off the head to see where the leak is and when I put it back on theres an exhaust leak...52 main for the jetting?
    JohnnyB's Avatar
    Nov 2003
    CT
    So , do you still have the oil leak or is it an exhaust leak ?
  10. #9
    JD50's Avatar
    May 2004
    Lafayette, La
    Still some oil leakin but I can hear exhaust comin directly from the head when I start it.
  11. #10
    JohnnyB's Avatar
    Nov 2003
    CT
    Did you remove the old gasket ? You may have 2 gaskets on there now ?
  12. #11
    JD50's Avatar
    May 2004
    Lafayette, La
    I just thought of something...could me having it at an angle on the stand(front end lower than back) for 2 days have something to do with it?
  13. #12
    JD50's Avatar
    May 2004
    Lafayette, La
    Quote Originally Posted by JohnnyB
    No it didn't come with a gasket. I was thinking of the metal thing that you bolt up to the head.
  14. #13
    JohnnyB's Avatar
    Nov 2003
    CT
    No . And if it did by any chance something is wrong with bike , broken mount or loose bolts .
  15. #14
    JD50's Avatar
    May 2004
    Lafayette, La
    So the problem is probably that I need a new gasket?
  16. #15
    JohnnyB's Avatar
    Nov 2003
    CT
    For the exhaust leak , yes . But for the oil leak , that has yet to be solved ???
140cc pit bike leaking oil out of exhaust
can oil leak from exhaust manifold port
clean oil from muffler pit bike
crf 50 leaks oil from header
crf50 black coming from exhaust
exhaust meets the?engine?i have?oil leaking?there?
honda nc50 leaking oil from exhaust
oil leak from exhaust port
pit bike leaking oil from the header
pit bike oil leak
why is oil dripping from exhaust on 140 cc pitbike?
xr 50 leaking water
