Rmz 250 engine problems. Help?
This is a discussion on Rmz 250 engine problems. Help? within the CRF50 forums, part of the General Talk category; Hi, I have a 2006 rmz 250 and when i started the bike, it started okay, but it wouldnt stay running even though the bike ...
Results 1 to 6 of 6
    ktm90's Avatar
    Oct 2005
    North East Ohio
    Hi, I have a 2006 rmz 250 and when i started the bike, it started okay, but it wouldnt stay running even though the bike was warm. i messed with the idle screw, but that didnt help. So i go to ride the bike and it starts back fireing pretty bad. A couple of laps later the bike starts to loose power. So i ride it back to the garage and go to park it when i noticed there was oil leaking pretty bad out of my crank case vent hose, oil was also leaking out of the left side of my head. Any ideas of what might be wrong?
    Thanks
    slapaho16's Avatar
    Apr 2006
    Fort Worth TX
    Re: Rmz 250 engine problems. Help?
    man this is planet minis not planet big bikes
    Riding 50s and slappin hoes
    LANG421's Avatar
    Apr 2004
    Riverside, California
    its a suzuki....that's your biggest problem. sounds like a possible blown head gasket....but who knows, take it to a local performance shop and have it checked out. it could be numerous things. from as minor as a head gasket, to as serious as a blown crank
    JCMINIS's Avatar
    Dec 2003
    Old fort,NC
    sounds like 2 problems running condition and oil leak they may be related may not
    have you ever adjusted the valves? we need tons more info.how much time is on it what mods do you have,,etc..
    JCMINIS
    07 KLX110
    09 YZ250
    08 CRF100
    KTMraca05's Avatar
    Nov 2004
    Breaux Bridge Louisiana
    Try messing with the air screw... It might be running too lean.
    Also, RMZ250's are notorious for overheating... I think Boyesen sells a water pump cover/impeller that is supposed to help with overheating...
    Staggs Racing!! Check 'em out!
    RcWannabe's Avatar
    May 2006
    Erie, Pa
    Sounds like a stuck open hot start, which can be caused by water running down the cable when you wash it
    Founder of the Fl Mullisha....Pa Chapter
07 rmz 250 problems
2005 suzuki rmz 250 oil leaking out of head cover
2006 rmz 250 header leaked
2006 rmz 250 problems
oil leaking from rmz 250
problems with the 2006 rmz 250
rmz 250 head gasket leak
rmz 250 head gasket oil leaking
rmz 250 leaking oil
rmz250 2015 head gasket leaking oil
rmz250 hot start problem
rmz250 problems
