At home valve job that works gy6 50cc
This is a discussion on At home valve job that works gy6 50cc within the GY6 scooter forums, part of the Scooter Forum category; All you have to do is take the head off and fill the port with brake cleaner.(either intake or exhaust) Then look at your valves ...
Results 1 to 7 of 7
    Bigt1995's Avatar
    Mar 2013
    All you have to do is take the head off and fill the port with brake cleaner.(either intake or exhaust) Then look at your valves in the combustion chamber for any leaks. If so take a drill and grab the top of the with the chuck and spin the valve until it feels smooth and spin in both ways.(A small cordless drill works the best)Finally refill with brake clean and test for leaks. This worked prefect on my gy6 83cc with a ported 50cc head. Lots of compression now the valve seats are good.
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    on mine i grabbed a second set of valve spring shim fro ma donor yx150 type engine and double shimmed my valve springs.
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    Quote Originally Posted by Bigt1995 View Post
    Hmm.....That's not a valve job.....hell that's not even lapping if your not using lapping compound. Also using a drill and chucking directly to the tip of the valve is a HORRIBLE practice.
    A valve job is when angle(s) or radii are cut or ground into the seat via machine
    Or can be done with neway hand cutters
    What you are attempting to do is called lapping. When lapping compound (which comes in a variety of grits) is placed on the valves seating face as seen here
    The valve is inserted back into the head and spun on the seat. The more common route to perform this action is with a lapping cup
    There are mechanical power lappers out there but they are pricey and not practical for the backyard dyi guy. For the dyi guy that wants to lap mechanically a drill can be used but.... As stated before chucking directly to the tip of the valve is a horrible practice and there's a laundry list of potential things the cam go on. The safe and easy on ur head/valve way to do it. Would be find a piece of tubing that fits really snuggly over tip of valve then chuck drill onto tubing (not valve stem) then give her hell
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    what's the difference between spinning it with a wooden handle and a drill? it's still going round and round. EDIT: i suppose with a cup one might spin it back forth.
    is tired of this bad weather!!
    hate the NW!!can't wait to
    move to AZ in oct
    ridered_508's Avatar
    Oct 2010
    Olympia, WA
    Quote Originally Posted by cdoublejj View Post
    Your grabbing the stem of the valve with the drill which is not good practice
    When using the proper tool your not harming the valve at all.. Just touching the "combustion chamber" part of the valve
    cdoublejj's Avatar
    Oct 2008
    USA, MO
    good point!!!
    Towlieee's Avatar
    Feb 2007
    When I replaced valves on my crf 50's "race head", I used a drill, but from a guide I found online, I used a small piece of tubing that held the valve tightly, like 2 inches long, then the other piece of the tube went over a screw that was chucked in my drill. I used lapping compound however.
    /old post I know, but looking up gy6 info and found this thread
  1. Bbr 4 valve motor with 6 disc clutch 4 speed, the works
    By colineunson in forum Feelers and What is my bike/parts worth?
    Last Post: 06-17-2012, 05:06 PM
  2. KLX Works shock (fresh from works)
    By Zmnypit in forum KLX110/Midsize Parts for Sale
    Last Post: 04-17-2010, 10:04 PM
  3. loncin 110cc 3 valve engine in 50cc z50j - 420 or 428 sprockets. need help
    By toby57 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-10-2009, 11:16 PM
  4. Replies: 1
    Last Post: 11-04-2007, 09:51 PM
  5. Replies: 6
    Last Post: 06-17-2005, 03:58 AM
4 valve 50cc head
gy6 50cc valve lap
gy6 cylinder head parts
gy6 head porting
gy6 ported head
gy6 valve seat
home valve job
honda 5cc scoooter valve job
how to check heads off 50 cc scooters
how to do a valve job at home
porting gy6 head
valve job at home
