Crf150r idle problem
This is a discussion on Crf150r idle problem within the Honda CRF150R And CRF150F forums, part of the General Talk category; So I have this 150r that was running like crap so I cleaned the carb and accidentally messed with the adjustment screw on the bottom. ...
Results 1 to 7 of 7
    mxhonda210's Avatar
    Mar 2013
    So I have this 150r that was running like crap so I cleaned the carb and accidentally messed with the adjustment screw on the bottom. Now it runs great but won't idle at all. I need to always be giving her gas. I don't have a manual so I don't know how to properly adjust the bottom screw.
    stunami's Avatar
    Jul 2008
    LAKES REGION N.H.
    ok you should be able to turn the air screw in or out to achieve a high idle then re adjust the idle screw to your desired idle you may need the D- shaped tool for the air screw adjustment though .
    i'm not real famliar with 150 carb
    stunami's Avatar
    Jul 2008
    LAKES REGION N.H.
    http://maultechatv.com/techguides/carbtuning.php HERES A LINK REAL GOOD INFO FOR ALL KEHEIN CARBS
    is Language....its english bitch
    Matthonda86's Avatar
    Feb 2011
    North Canton, Ohio
    air screw=2 turns out is a great starting point. fuel screw=1/4 to 1/2 turns out is normal I believe
    Sometimes I go fast, but most of the time I just think about it.
    Luckystar64's Avatar
    Feb 2007
    Brunswick, Ohio
    If it's an '07 then they did have idling problems. I've had two of them and neither liked to idle. I did go up slightly on the pilot jet, and that did help. The '08's ran that mod stock. --L*64
    minimeracing's Avatar
    Nov 2005
    Massachusetts
    JD jet kit, R&D flex jet and a Boysen quick shot 3, You won't believe it's the same bike! JD jet kit for sure. I have 3 150rs 2007,2008,2012 all have JD jet kits and it helps alot.
    Cpushic01's Avatar
    Jul 2016
    Quote Originally Posted by minimeracing View Post
    Will the JD jet kit help the bike idle better?
  1. Idle problem?
    By klx110 lover:) in forum KLX110, DRZ110, TTR90
    Last Post: 04-29-2013, 09:19 PM
  2. My next problem: Won't Idle
    By Turbo Supra in forum Bigger Minis Forum
    Last Post: 10-21-2009, 06:00 PM
  3. idle problem
    By bean312 in forum CRF50
    Last Post: 01-29-2009, 02:43 PM
  4. idle problem
    By tangkenboo2 in forum CRF50
    Last Post: 04-13-2007, 12:46 AM
  5. Major idle problem..need help.
    By fastbmw in forum CRF50
    Last Post: 04-07-2006, 03:01 PM
2009 honda 150r idle issues
adjust idle on 2004 honda crf 150
crf150r carb adjustment
crf150r idle
crf150r problems
crf150r wont idle
honda crf 150 idle adjustment
honda crf 150f won't idle
honda crf150f carb adjustment
honda crf150f idla screw 2008
honda crf150r carburetor problems
honda crf150r problems
