Engine Noise????
Engine Noise????
This is a discussion on Engine Noise???? within the Honda CRF70 forums, part of the General Talk category; I bought my girlfriend a 99 xr70, didn't run but cleaned the carb and got it running. There is a ticking or knocking noise coming ...
Results 1 to 6 of 6
    b-dub675's Avatar
    Sep 2008
    kalamazoo michigan
    Engine Noise????
    I bought my girlfriend a 99 xr70, didn't run but cleaned the carb and got it running. There is a ticking or knocking noise coming from the left side of the motor. I didn't let it run long, something definitely isn't right. Checked oil, and valves, timing, the cam chain tensioner spring is longer than it should be, so i bought new cam chain, spring and the plastic cap for the tensioner. Getting ready to put back together just wondering if there is anything else i should check while i have it all apart.
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    Re: Engine Noise????
    How much longer was the worn cam chain? I've seen some real streched ones.
    b-dub675's Avatar
    Sep 2008
    kalamazoo michigan
    it really doesnt look that much shorter than the old one, like almost identical. i had the stator plate off and was kicking it over and the tensioner moves like crazy. i dont know if thats normal. and my girlfriend almost took the chain off by hand with the tensioner in
    is Trying to have alittle fun in
    life!
    Grafixxs's Avatar
    Apr 2007
    Marshall,MI
    dub, you ready to put some zokes on that bike yet? I got a set of KTM 65 forks coming off a bike real soon.
    Cam chain tensioner is bad, replace it.
    b-dub675's Avatar
    Sep 2008
    kalamazoo michigan
    got crf80 forks on the way.
    kitchen157's Avatar
    Sep 2008
    Marcellus, MI.
    Looks like you are going to need a longer swingarm now
2002 xr70 cam tensioner install
2002 xr70 engine knocking
crf 70 cam chain noise
crf70 cam chain noise
crf70 engine noise
ct70 ticking noise from engine when put on kickstand
honda xr70 engine noise
how do i adjust 99xr70 carburetor
xr70 engine noise
xr70 nock in engine
xr70r had engine tick
