Questions on Recently Purchased CRF70
This is a discussion on Questions on Recently Purchased CRF70 within the Honda CRF70 forums, part of the General Talk category; I recently purchased a used 04 CRF70. I am having a problem with the idle. When the bike is completely warm up and I close ...
Results 1 to 4 of 4
    JaxFLCRF70's Avatar
    Apr 2009
    Jacksonville, Florida
    I recently purchased a used 04 CRF70. I am having a problem with the idle. When the bike is completely warm up and I close the choke, the engine idles really low then eventually stalls. How do I go about fixing this problem?
    Also the bike smokes a good amount, a bluish/white smoke. Is this common for these bikes? I am guessing the engine is going to need a rebuild. Anybody know a good rebuild kit or maybe a stroker kit, that comes with the head,piston,crankshaft, maybe a race camshaft, carburetor?
    Thanks
    Korbenw7p3c's Avatar
    Jun 2006
    central Illinois
    Re: Questions on Recently Purchased CRF70
    ...the first thing that I would do is adjust the valves. Secondly, the carb might need to be cleaned. Afterwords, when reassembling the carb, set the air/fuel screw 1.5 turns out from LIGHT seated position. This is a good starting point for the screw adjustment. Adjust the idle from there after you've ridden it for at least 15 minutes. You should be set.
    If it continues to smoke after these adjustments, then it's time for a rebuild.
    is willing to give my right nut
    have my 70 fiinally finished..
    PTECH's Avatar
    May 2009
    Scottsdale, AZ
    I'm trying to get my new 04 70f running better. I notice there are two adjustment screws on the side of the carb. One has a phillips and one has a flathead. The one with the flathead is angled down and the phillips goes straight. It seems like the one with the phillips is an idle speed adjuster. The other one is the fuel screw?
    Lukemx151's Avatar
    Dec 2008
    Scottsdale az
    i had that same idle problem with my 70 but all you have to do is adjust that phillips screw and it seemed to work fine
crf 70 idle issues
crf 70 smokes after rebuild
crf70 white smoke
crf70 white smoke with choke on
crf70f carburetor pilot screw turns out
honda crf 70 smokes
honda crf70 white smoke
idle speed on 2006 honda crf 70
what causes white smoke on crf70
what makes 09 crf70 smoke
