Differences between crf 50 and 70 motors?
This is a discussion on Differences between crf 50 and 70 motors? within the Honda CRF70 forums, part of the General Talk category; So obviously the top ends are different, but I was wondering what the differences are in the bottom end. I have heard that the transmission ...
Results 1 to 13 of 13
    is Slangin parts at
    down2mob.com!!
    Down2Mob's Avatar
    Aug 2009
    Phoenix, Arizona
    So obviously the top ends are different, but I was wondering what the differences are in the bottom end. I have heard that the transmission is different.
    is currently licking windows
    doopsx3's Avatar
    Aug 2008
    Yucca Valley
    Re: Differences between crf 50 and 70 motors?
    I believe the trans itself is the same but the primary drive is different ratio and the 70 has a higher volume oil pump.............(I think)
    zwieblekopf's Avatar
    Mar 2009
    Mesa, AZ
    what doops said plus heavier duty clutch
    doopsx3's Avatar
    Aug 2008
    Yucca Valley
    Quote Originally Posted by zwieblekopf
    yeah...4got about the heavier clutch
    sr20hardbody's Avatar
    Jan 2008
    iowa
    dont forget the 3rd bearing i think the 50 uses a seal instead
    tranny's have same part # its mainly the primary gearing, oil pumps and clutch springs that differ
    is just truckin' along...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Quote Originally Posted by sr20hardbody
    Would you like to elaborate a little on this, for those of us who haven't heard of the 3rd bearing, please?
    - dirtbkr188 -
  7. #7
    Jan 2008
    iowa
    sure thing
    if you look at the difference between both pics you'll see the 70 has an extra part #14
    Honda Yamaha Suzuki Kawasaki Sea-Doo Can-Am Ski-Doo Motorcycle Parts ATV parts Scooter Parts personal watercraft parts Accessories
    i also forgot the 70 uses a thicker conrod but from what im told its not needed just extra weight.
  8. #8
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Got it, the needle bearing for the shift shaft that's in the right side cover. It is just a machined hole inside the cover for the 50.
    Thank you...
    - dirtbkr188 -
  9. #9
    Jan 2008
    iowa
    you're welcome but curious could that bearing be installed into the 50 cover or is that machined hole not the right size?
  10. #10
    dirtbkr188's Avatar
    May 2004
    New Jersey
    There is enough material all around the machined hole to enlarge it for that 1010 bearing, but it might be better to just get a 70 clutch cover. That is a precision fit, otherwise, the shift shaft will bind if the bearing is installed incorrectly.
    - dirtbkr188 -
  11. #11
    Jan 2008
    iowa
    hmm thats $95 shipped
    i wonder if FPM would machine it for much MUCH cheaper
  12. #12
    is Slangin parts at
    down2mob.com!!
    Down2Mob's Avatar
    Aug 2009
    Phoenix, Arizona
    okay cool, I am wondering because I have a stock 70 and want to just buy a mod 50 motor and throw it in there. I'm sure I wouldn't have any problems doing this right?
  13. #13
    Jan 2008
    iowa
    port your stock 70 head add a cam and get a tb 88cc bbk with the dome piston.
    wish it were that easy for me i have to build my 50 motor to 70 status first which costs a lot!
    and 50 motor will bolt right in if thats the route you choose.
are crf 50 and crf 70 engines the same
crf 70 motor
crf 70 motor in crf 50
crf 70 shift
crf 70 top end in a 50 motor
difference between 50 and 70 crf motors
difference between crf 50 and 70
difference between honda crf 50 and crf 70
motor difference between crf 50 and 70
whats better to stunt a crf 50 or a crf 70
whats the diff between hondas 70 crf and rt
whats the difference between a crf50 and 70
