XR70 w/ TB88 I need more torque
This is a discussion on XR70 w/ TB88 I need more torque within the Honda CRF70 forums, part of the General Talk category; I have an XR70 that I installed a TB88 kit on. I put the TB cam in and the 20mm carb. I don't care about ...
I have an XR70 that I installed a TB88 kit on. I put the TB cam in and the 20mm carb. I don't care about top end, just torque for my son on the track. I need any tips available. I currently have a 14t front sprocket and 36t rear. I am considering putting the stock carb back on for more bottom and/or putting the factory cam back in which has a shorter duration. What are the experienced thoughts on either of these routes? If I replace the OEM carb, any tips on jetting with a stock exhaust?
My problem is 1st and 2nd have such a big gap that my son (7years old @ 54lbs) tends to stay in 2nd which is to tall coming out of the turns and up the hill.
05-01-2012 07:55 PM
Re-gear it to a 13 or even 12 tooth front sprocket. That should help tremendously
if you drop to a 12 tooth it becomes a 2 speed tranny, just 2nd and 3rd. Was he racing at durhamtown?
Theres always the takegawa 3 speed transmission. About 200 bucks but you'll have 3 close ratios work with inside the trans so you're not left trying to work around a lousy transmission with your final drive like you are now. I run one in 70 and its brillant, I hate riding bikes without it now.
Agreed with GAjonn, first gear would be useless going down. If you want more torque, adding the trail bikes 51mm stroker crank helps tremendously!
Putting a 13th on is the ticket! It finds a happy medium which is noticibly better. It's only a $10 part so it can't hurt to try.
takegawa or kitaco 3 speed kits are the only way to lose the massive gap between 1st and 2nd, gearing it will just make 1st gear useless
Originally Posted by
Jordo
stroke and punch it to a 108
- You may not post replies
- You may not edit your posts
Forum Rules
By fatcaaat in forum CRF50/CRF70 Parts For Sale
Last Post: 08-02-2010, 03:14 PM
By xlxrman in forum CRF50
Last Post: 02-20-2010, 01:17 AM
By thorwarrior915 in forum CRF50/CRF70 Parts For Sale
Last Post: 01-04-2006, 01:48 AM
By nebnosnevel in forum CRF50
Last Post: 08-16-2004, 09:47 AM
By Foxxxr70 in forum CRF50
Last Post: 07-18-2004, 08:00 PM
best 88 kit for xr70
crf 70 88 kit
crf70 top end for 50
crf70 withh 88 kit
honda crf 70 88c kit- head
how to get more torke in a honda xr70
stroker crf70
tb88
tb88 stock head 50
xr 70 stock sprocket ratio
xr50 88 kit xr70 head
xr70 gearing torque
