Plastic in carb blocking float needle - Where's it coming from?
This is a discussion on Plastic in carb blocking float needle - Where's it coming from? within the Honda CRF70 forums, part of the General Talk category; 2002 XR70R stock Recently bought for my son. Replaced plug, changed oil, cleaned filter and the bike runs fantastic! Twice I've found small bits of ...
Results 1 to 6 of 6
    hoosier's Avatar
    Aug 2015
    2002 XR70R stock
    Recently bought for my son. Replaced plug, changed oil, cleaned filter and the bike runs fantastic! Twice I've found small bits of black plastic (grain of sand size) stuck in the carb preventing the float needle from seating and resulting in fuel dumping out of the overflow. In the short term I'd like to just install a fuel filter to catch the plastic. In the long term I'd like to replace whatever is falling apart. Apologies for such a generic question. The bike is at my old mans. I'm Navy and doing a quick stop over for the weekend. I want to have the parts there so I can have the bike running when my son wakes up on Saturday. Thanks for the assist.
    - What fuel filter do you recommend? Please provide size and manufacturer if you can.
    - Where is the plastic coming from? Fuel lines, tank? Hopefully, there's a trend that you can point me too.
    is Railin ruts and lickin the
    booty
    Bluerider106's Avatar
    Oct 2014
    Socal
    I'd drain the tank and remove the pet cock. Inspect the petcock really well and I'd probably replace it. The petcock has a filter on it!
    Flush the tank super well with a hose and then let the tank dry out for a few days. Clean the carb again. Reasemble and add fuel. Problem solved.
    LILFIFTY's Avatar
    Dec 2009
    waukesha, WI
    Maybe replace the fuel line for good measure as well
    tmas's Avatar
    Apr 2005
    TO
    TBolt sells some in line fuel filter for extra assurance. Check link.
    Search Results - Advanced Search - TBolt USA, LLC
    mrjetskey's Avatar
    Jan 2015
    Its the tank if its black plastic, petcock if its rubber
    Quote Originally Posted by hoosier View Post
    2002 XR70R stock
    I found that removing tank cleaning it (petcock is to expensive) if its a 2008 or earlier the brass screens or plastic in petcock will be no good, so get some clear tygo fuel line ,put in a clear fine fuel filter not paper ,droop fuel line down so the loop will trap plastic parts and you can see all the pieces and instead of plugging fuel filter they will settle in bottom of loop. Then after a few rides you can remove fuel line from filter on one end and flush the pieces gathered in fuel line loop ,you wont have any more carb problems. Pretty soon after regular use you wont see any more plastic. The plastic comes from letting fuel get old and it eats inside of fuel tank. PS the petcocks sold on ebay don't fit genuine Honda tank. So its cheaper if you want to replace petcock to buy tank and petcock for 25.00 on Ebay.ps still use the clear fuel line and inline filter for best results. PS I installed an 88cc kit with updated electric cdi,and pipe. The little critter runs really good for what it is, engine is great suspension well ?????? Thanks >Marvin
    Freshhere's Avatar
    Sep 2016
    Secret to be told
    Search Results - Advanced Search - TBolt USA, LLC Tbolt is a great company i recommend them
  1. Mikuni VM26 carb, Stock Float needle size?
    By DirtForceMotorcycles in forum Roost Area
    Last Post: 07-02-2015, 06:37 PM
  2. WTB Stock 2006 KLX 110 Carb Float Needle
    By cav1er in forum Bikes and Parts Wanted - All Makes
    Last Post: 03-16-2013, 02:25 AM
  3. float bowl needle?
    By 1978 minitrail in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 08-09-2012, 11:45 AM
  4. 2010 plastic coming soon
    By zimm17 in forum KLX110, DRZ110, TTR90
    Last Post: 10-20-2010, 05:34 PM
  5. VM26 Float Needle Seal
    By xlxrman in forum CRF50
    Last Post: 10-30-2009, 12:15 AM
Tags for this Thread
