Help - CRF 70 is burning oil after 88 kit install
This is a discussion on Help - CRF 70 is burning oil after 88 kit install within the Honda CRF70 forums, part of the General Talk category; I installed the CRF88 kit on the CRF70 base engine and it's burning oil - I can smell it, but it doesn't blow smoke. It's ...
Results 1 to 5 of 5
    jrod4928's Avatar
    Sep 2016
    It's the version with the stock head and high volume oil pump. I adjusted valves to 0.003 clearance.
    Any idea on how/where the oil is getting in? Is the valve clearance too small? It didn't have this problem before installing the kit.
    Thanks!
    silvjorr's Avatar
    May 2008
    Estonia
    It can be the oil You used when mounting the kit?
    Silver
    jrod4928's Avatar
    Sep 2016
    Nah - the engine has been run for at least 2 hours and it's still the same as when it first started up.
    The guys at T-Bolt told me they think the valve seals may have been slightly leaky, and the extra bore makes it worse so that it just leaks a tiny bit. They aren't concerned. I don't think it's a huge deal either, just wondering where to start fixing it and if there are any other theories out there.
    is zero fox given
    rustynuts's Avatar
    May 2014
    Norcal
    if all the rings are lined up with the gap in the same place it will burn a bit of oil. Could also be as tbolt mentioned bad stem seals. I rebuilt a trail 90 a couple years ago that had tons of oil in the exhaust. It took several days of riding to get the exhaust to stop smoking.
    Check out my Pitster mini monster zb50 thread: Hidden Content
    jrod4928's Avatar
    Sep 2016
    This is more weird. ..
    On 2 separate occasions after riding for a little while and shutting the bike off. We tried starting it and the kick starter wouldn't budge no matter how hard you push down. After waiting a while, we kicked it and it started right up.
    Is the piston seizing? Why would this be happening?
  1. Burning oil need help!!!
    By PitsterFreak in forum Chinese/Import Minis - General Discussion
    Last Post: 04-20-2010, 01:10 PM
  2. Burning oil need help!!!
    By PitsterFreak in forum Pitster Pro
    Last Post: 04-19-2010, 11:27 AM
  3. burning oil
    By drz143 in forum KLX110, DRZ110, TTR90
    Last Post: 06-09-2009, 03:00 PM
  4. 03 xr 50 burning oil
    By fred88gt in forum CRF50
    Last Post: 03-17-2009, 08:43 PM
  5. burning oil?
    By woodsracer in forum CRF50
    Last Post: 09-18-2005, 09:51 PM
