04 crf70 carb issues
This is a discussion on 04 crf70 carb issues within the Honda CRF70 forums, part of the General Talk category; Hey guys ,,, I'm new here from st.matthews s.c ,,, I just purchased a 04crf70 and a 03xr70 as a parts bike ... Long story ...
Results 1 to 5 of 5
    kapgar's Avatar
    Sep 2016
    South carolina
    Hey guys ,,, I'm new here from st.matthews s.c ,,, I just purchased a 04crf70 and a 03xr70 as a parts bike ... Long story short ,,, I needed a stator and base.... got the 03 for 100$ ,, got my crf running but its cutting out after more than half throttle ,,, I had to use a carb that was larger than spec carb... Pretty sure that's why it's cutting out but honestly I'm new to this and I am wondering if I take the throttle cable loose and lower the needle would that limit the fuel possibly and help stop the bogging down after anymore than half throttle
    Jose777's Avatar
    May 2016
    Fontana cali
    the bogging down usually happeneds when the pilot jet is clogged ,take the float bowl off and with a flathead screwdriver remove both jets , u should be able to see thru both of them if not their clogged
    kapgar's Avatar
    Sep 2016
    South carolina
    Jets are clean and clear ... It ran decent with the choke roughly 1/3rd open ,, I took the carb back off and put new gaskets and springs on mixture and pilot screws,, this aftermarket carb. Im having to use has a adjustable float and the orig. Carb. Didn't ,, after the carb. Refresher kit it's cutting out after 1/4th throttle and runs like trash with or without the choke opened or not
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Have you adjusted the clip on the needle at all? How far out is the air screw from seated? A pic of the carb you're working with will be a big help.
    - dirtbkr188 -
    kapgar's Avatar
    Sep 2016
    South carolina
    OK ... Soon as I get back to the house I'll take a pic of it ,,, I preciate the information and fast response too !!
  1. On-going rich carb issues on stock ct 70, last effort before carb purchase
    By Expygator in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 09-19-2013, 09:10 AM
  2. 05 Crf70 With Carb Issues...
    By zkattered in forum Honda CRF70
    Last Post: 04-18-2011, 09:31 PM
  3. carb issues
    By 802xcrf88 in forum CRF50
    Last Post: 01-02-2011, 07:09 PM
  4. Carb. Issues....
    By Racinkc in forum CRF50
    Last Post: 03-09-2010, 05:11 PM
  5. Replies: 6
    Last Post: 04-21-2009, 05:19 PM
