CRF70 TX swing arm help
This is a discussion on CRF70 TX swing arm help within the Honda CRF70 forums, part of the General Talk category; Hello, New here, and stripped a CRF70 down to the frame and am building it from scratch. I'm trying to do it one section at ...
Results 1 to 8 of 8
    Pengu's Avatar
    Oct 2016
    Hello,
    New here, and stripped a CRF70 down to the frame and am building it from scratch. I'm trying to do it one section at the time, and decided to start with the rear. I purchased the TRC One swingarm from TBolt. I am aware I am going to need to get a custom bracket created for the shock.
    My issue is, I am new to all this and am trying to learn. I've watched a few youtube videos and got the general concept down. But how am I supposed to put the bearings in on the swingarm. All the videos I could find are slightly different then what came with the swing arm.
    Can anyone help me with how I should be put it all together?
    Link to purchased swingarm:
    TRC ONE X4 TX SWINGARM KIT - TRC-2274 - Frames & Swingarms - Pit Bike Chassis Parts - TBolt USA, LLC
    is 12 0 clock
    sticky5280's Avatar
    Feb 2014
    Denver, CO
    Quote Originally Posted by Pengu View Post
    Hello,
    Post pics
    Pengu's Avatar
    Oct 2016
ID:	192177Click image for larger version.
ID:	192185Click image for larger version.
    Here you go. I can get more pics if needed.
    donmx14's Avatar
    Jan 2009
    latrobe, pa
    The parts can only go in one place, bearing mount on outside. Bushings on inside. Stepped bushings are for shock mount
    Pengu's Avatar
    Oct 2016
    So I think where I got confused was with the collars, but I heard from someone else saying I may not need to use these. To just press the bearings in, and the sleeves go in the center.
    donmx14's Avatar
    Jan 2009
    latrobe, pa
    If you go to the link you posted and look at the picture you can clearly see where they go
    donmx14's Avatar
    Jan 2009
    latrobe, pa
    The stepped bushing/collars push in on outside of shock mount. They are needed
    Pengu's Avatar
    Oct 2016
    Quote Originally Posted by donmx14 View Post
    Yup, I agree. The issue I was having was where the collar bolts need to go. But apparently, I do not need them.
  1. Crf70 Swing arm
    By aaron70 in forum Honda CRF70
    Last Post: 07-21-2016, 04:22 PM
  2. Kx swing arm on crf70?
    By johnson731 in forum Honda CRF70
    Last Post: 04-02-2014, 08:37 PM
  3. crf70 swing arm
    By bikealldayeerday in forum CRF50
    Last Post: 02-14-2011, 01:43 PM
  4. looking for crf70 swing arm
    By live breath ride in forum Bikes and Parts Wanted - All Makes
    Last Post: 01-29-2009, 11:26 PM
  5. looking for a crf70 swing arm
    By live breath ride in forum CRF50/CRF70 Parts For Sale
    Last Post: 01-29-2009, 11:09 PM
