Crf50 hub vs Crf70 hub
This is a discussion on Crf50 hub vs Crf70 hub within the Honda CRF70 forums, part of the General Talk category; This may be a dumb question but will a crf50 hub work on a crf70? I ask because I'm trying to run 12" wheels with ...
Results 1 to 4 of 4
    meble's Avatar
    Nov 2016
    This may be a dumb question but will a crf50 hub work on a crf70? I ask because I'm trying to run 12" wheels with super moto tires on my 70 and have found a 12" wheelset with tires but they have crf50 hubs. All they would need are the brake assemblies.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    To use the CRF50 hubs and brake panels you would have to move the brake panel stop on the 70 swingarm closer to the axle slot for the rear brake panel to work right.
    On the front, you either have to grind down the brake panel tab to fit in the slot of the 50 brake panel, or drill and tap the brake panel tab for a 6mm bolt (10mm head) and use the 50 brake panel that way.
    - dirtbkr188 -
    meble's Avatar
    Nov 2016
    Thanks. Would the 70 brakes work with the 50 hub?
    What's the easiest way to get a 12" wheelset for a stock 70? Lace a 12" rear rim to the stock hub?
    dirtbkr188's Avatar
    May 2004
    New Jersey
    No, the 70 brake panels are bigger and a totally different design.
    The rear wheel of a stock CRF70 is a 12" rim, you would need to lace a 12" rim to the front hub and have spokes custom made
    - dirtbkr188 -
  1. Klx 110 Rear Sprocket hub or Kx65 Hub with Rotor
    By TAR MX in forum Bikes and Parts Wanted - All Makes
    Last Post: 01-06-2016, 08:14 AM
  2. WTB BBR front brake setup w/hub or without hub. .
    By mutinytattoo in forum Bikes and Parts Wanted - All Makes
    Last Post: 12-16-2009, 05:18 PM
  3. Crf50 -rear Hub,sano Skid,front Hub
    By ccracer in forum CRF50/CRF70 Parts For Sale
    Last Post: 10-07-2006, 07:25 PM
  4. honda rear wheel,r hub,frt hub,brk panel,parts
    Last Post: 06-30-2006, 11:59 AM
  5. WTB: Bombshell hub and 10in spokes, and stock crf/ttr rear hub and brake
    By ttr50rider12 in forum CRF50/CRF70 Parts For Sale
    Last Post: 06-01-2006, 03:33 PM
