Piranha 140 Motor Swap Concerns
This is a discussion on Piranha 140 Motor Swap Concerns within the Honda CRF70 forums, part of the General Talk category; So I'm seriously considering getting the Piranha 140 to drop in my 70, but the only thing holding me back is that I dont know ...
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By dirtbkr188
Thread: Piranha 140 Motor Swap Concerns
    is "I don't crash, I have
    slightly uncontrolled
    get-offs"
    Honda_Rider_710's Avatar
    Nov 2014
    So I'm seriously considering getting the Piranha 140 to drop in my 70, but the only thing holding me back is that I dont know whether the stock exhaust will fit. I ride in my neighborhood a lot and trails where spark arrestors are required. Some people say that it will fit and others say that it won't (the pipe isn't long enough to reach the tab). And I was about to order one but I saw a picture of a 70 with a 140 and the exhaust was being held on with Vice grips, and the holes don't line up correctly.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You can double check with Vince at T-Bolt but I think the Piranha 140 cylinder is 6mm taller (69mm) than the stock 70 cylinder, meaning the pipe mount will be 6mm forward of the mounting hole on the subframe.
    T Bolt USA likes this.
    - dirtbkr188 -
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    Here some tech help
    LINK:
    TBolt USA Tech Database - TBolt USA, LLC
    The stock pipe will bolt directly on to the head , however you will need to make a small bracket to hold up the muffler
    also
    another product that will help alot is an aftermarket peg mount
    T Bolt USA - Let's go riding!
    get-offs"
    Nov 2014
    Quote Originally Posted by T Bolt USA View Post
    Here some tech help
    LINK:
    also
    Thanks for the help. I have a few more questions though, can I use my stock 70 kill switch or do I need to order a new one. Also I read somewhere to get the T3 Throttle cable, is that correct?
    bikes !!
    T Bolt USA's Avatar
    Jan 2005
    Pennsylvania
    You can use the stock kill button
    TBW0301 throttle cable
  1. Which Motor??? Piranha 140 or SSR 140
    By RTKowzer31 in forum Chinese/Import Minis - General Discussion
    Last Post: 05-29-2015, 12:06 PM
  2. CT70 with piranha 140 swap wiring help
    By redttalms in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-26-2015, 10:22 PM
  3. Piranha 140 motor
    By jrmywyer in forum Import/Chinese Parts for Sale
    Last Post: 09-05-2013, 11:24 PM
  4. Cam Swap on a Piranha 140, give me some direction?
    By Frostflowz in forum Chinese/Import Minis - General Discussion
    Last Post: 07-01-2013, 03:32 AM
  5. 06 crf 70 with piranha 140 motor
    By 4lookz in forum Complete Bikes For Sale - All makes and models
    Last Post: 12-05-2012, 10:50 PM
