Stalls when warmed up
This is a discussion on Stalls when warmed up within the Honda CRF70 forums, part of the General Talk category; Background: Having an issue with my bike. I recently picked it up and know it had been sitting for awhile. I could start it but ...
Results 1 to 15 of 15
    jamesfl's Avatar
    Dec 2016
    Background:
    Having an issue with my bike. I recently picked it up and know it had been sitting for awhile. I could start it but it was running rough so I cleaned the carb including the jets and set the valve lash to 0.05mm. The needle is set at 3rd notch from the top and the air filter is clean.
    Once I did all this I was able to start the bike in 1 or 2 kicks with the choke off. It's 80+ degrees here in Florida. I adjusted the air/fuel screw and set the idle. I do occasionally get a little puff of white smoke coming back out of the air filter when starting but I am running rec gas with Sea Foam.
    Now the issues:
    While riding the bike, it will sputter like it wants to back fire when you let off the throttle.
    The main issue though is that once the engine warming up it dies. I can only get it started again with the choke on. If I try closing the choke, even slowly, I can hear it sucking in air a then it dies.
    Any idea what the issue/s might be?
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    Try opening the vale lash a smidge. As if thermal expansion is causing the valves to leak when the stems get hot. Especially the exhaust valve.
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Popping on decel is usually indicative of a lean condition, quite possibly your carb passageways are partially blocked, and/or you have an air leak in the head/manifold area or the carb/manifold area. While maintaining a steady idle, spray some brake or contact cleaner in the above mentioned areas, and see if there is an increase/decrease in RPM level, then a return to steady idle. If that happens, you usually have an air leak
    - dirtbkr188 -
    jamesfl's Avatar
    Dec 2016
    Thanks for the suggestions guys. I would try them both now, but getting ready to take my son to the Mini Motor track for the 1st time!
    Dirtbkr you might be on to something about the leak. I thought I could hear a sucking sound but could not isolate where it was coming from. Even tried removing carb from the intake manifold to check the condition of the heat spacer.
    I will update after checking things tomorrow.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Just an FYI, a light coating of engine oil or wheel bearing grease on all of the gaskets and/or o-rings in both of those areas will help make a seal and eliminate them as the source of the leak.
    - dirtbkr188 -
    jamesfl's Avatar
    Dec 2016
    Awesome thanks for the tip
    jamesfl's Avatar
    Dec 2016
    We missed practice day due to a change in scheduling so...
    Tried spraying brake cleaner in both areas dirtbkr recommended with no apparent change in idle. Figured I would try that before loosening the valve lash a tad as kirrbby recommended.
    The bike is now smoking with smoke also coming out from between the crankcase and cylinder head and the values tapping seems louder than yesterday. I am guessing I need new piston rings but as I said I am learning as I go and need your expertise. Tried to upload a video but keep getting an error. I can try PM'ing the video if someone can help.
    Please tell me what you guys think.
    BTW, I do have a new pz20 carb and petcock being delivered tomorrow to try and address fuel leak issues.
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Is it a leak where the pipe goes into the head? Possibly the pipe flange isn't seated flush with the gasket, and you have an exhaust leak?
    - dirtbkr188 -
  10. #9
    jamesfl's Avatar
    Dec 2016
    I only checked both sides of the intake manifold. I will pull the exhaust and reinstall it as well as loosen the valve lash today.
    Still can't post the video. Says can post due to a network error.
  11. #10
    jamesfl's Avatar
    Dec 2016
    Think I may have found the potential problem.
    Went to install the new carb (20mm).
    Removed the intake spacer to apply some grease as dirtbiker recommended to make sure it isn't leaking. That's when I noticed this.
    It appears the spacer is a 17mm spacer.
    On top of that the intake manifold looks to be either a 25 or 26mm intake.
    I have a 22mm Takegawa intake manifold I was going to try but unfortunately it is straight and not angled so I would be able to fit the carb.
    Do you think this could be causing the issues I described?
  12. #11
    dirtbkr188's Avatar
    May 2004
    New Jersey
    You can do one of two things here, IMO...
    1. Use one of these to enlarge the hole in the insulator, or
    2. Bolt the carb right up to the manifold without the insulator, just put a little grease on the carb o-ring before bolting it up.
    - dirtbkr188 -
  13. #12
    jamesfl's Avatar
    Dec 2016
    That or order a 20mm insulator and gasket off of eBay or Amazon.
    Do you think that the insulator was mostly likely culprit then?
  14. #13
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Quote Originally Posted by jamesfl View Post
    That's hard to say, but, if you try it without the insulator and it works alright, then you would know it was the culprit.
    - dirtbkr188 -
  15. #14
    jamesfl's Avatar
    Dec 2016
  16. #15
    jamesfl's Avatar
    Dec 2016
    I haven't had a chance to ride the bike again since replacing the intake spacer, carb, and tank but I did noticed a spot of oil under the front of the motor yesterday. The bike has been on a stand with the front tire on the ground so the engine is tilted slightly forward.
    It appears the drop of oil came from the exhaust port on the head.
    Would this be normal when an engine is stored in this position or is a sign I may need new piston rings?
  1. Ct 70 stalls under load
    By Expygator in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 05-20-2015, 01:22 PM
  2. Stalls out when put in gear....
    By Raym in forum KLX110, DRZ110, TTR90
    Last Post: 03-16-2014, 07:57 AM
  3. HELP crf50 stalls when choke is off
    By hjw_92 in forum CRF50
    Last Post: 06-24-2013, 08:01 PM
  4. klx110l bog and stalls sometimes
    By gibster1992 in forum KLX110, DRZ110, TTR90
    Last Post: 04-14-2013, 01:13 PM
  5. Xr 70 Stalls If Idling In Gear
    By ctxj93 in forum Honda CRF70
    Last Post: 07-26-2012, 08:48 PM
