Shift Lever hitting Engine cover
This is a discussion on Shift Lever hitting Engine cover within the Honda CRF70 forums, part of the General Talk category; Need some help from you CT70 owners. When I picked up this bike the shift lever was mounted only half way on the spline and ...
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Like Tree2Likes
Thread: Shift Lever hitting Engine cover
    jamesfl's Avatar
    Dec 2016
    When I picked up this bike the shift lever was mounted only half way on the spline and angled down further then I would normally position it.
    I now realize that was done purposefully. When you mount the lever properly, you can shift the lever downward but if you try to shift it upwards, it hits the engine cover. This is a 3 down transmission. I don't like the lever mounted 1/2 way on the spline as it is starting the damage the grooves.
    I am thinking that the shape and depth of the more modern CRF50/70 engine covers may be the issue.
    Tried two different engine covers and 3 different shift levers and still have the problem.
    Anyone else ever encounter this? If so, how did you solve the issue?
    I am assuming the answer will be get a CT style cover, which leads to my next question. Are there any budget CT aftermarket engine cover?
    Or perhaps I should try a lever like one of these:
    is grateful again...
    dirtbkr188's Avatar
    May 2004
    New Jersey
    Because the newer 12V CDI engines have a crank end that is 3/8" wider than the early 6V points-type engines, the engine covers are also wider. As you said above, you will need either a CT70 or a '68-'87 Z50 ignition cover in order for the shift lever to clear.
    RAZZO likes this.
    - dirtbkr188 -
    jamesfl's Avatar
    Dec 2016
    You sir are a true wealth of knowledge. Thank you again for all your help.
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    The crf/xr 12 volt motors use a shift shaft that is about 1/2" longer. So you can also swap in a new shift shaft for some clearance on the 12 volt type covers.
    jamesfl's Avatar
    Dec 2016
    Would that involve splitting the case?
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
    No, but you'd need to pull the clutch and primary gear. It installs from the right side of the engine.
    jamesfl's Avatar
    Dec 2016
    Just found a post on how to replace it. Looks like I either spend $50 to 60 for a new cover or $40 plus seal and gasket and have to pull the motor apart. If this was on the motor I already have partially disassembled I might go with a new shaft.
    jamesfl's Avatar
    Dec 2016
    I do like the idea thou kirrbby. Especially since I have some minor spindle damage. I will have to remember that for down the road.
  10. #9
    kirrbby's Avatar
    Aug 2014
    Davison Mi.
  11. #10
    jamesfl's Avatar
    Dec 2016
    Thanks! I thought the part was discontinued and eBay was my only option.
  12. #11
    loopiemclooperson's Avatar
    Oct 2011
    Maple Valley WA
    Here is the shifter you need.....
    https://tboltusa.com/store/pitbike-f...aft-p-207.html
    Takegawa makes pretty ones also, if that's your jam.
    Sent from my SCH-I545 using Tapatalk
    kirrbby likes this.
  13. #12
    jamesfl's Avatar
    Dec 2016
    I will admit that's do like the blingy parts.
  14. #13
    Oct 2011
    Maple Valley WA
    Here is the one I am running....
    http://japan.webike.net/products/21594698.html
    This one is cool too....
    http://japan.webike.net/products/2183271.html
  15. #14
    jamesfl's Avatar
    Dec 2016
    Nice! Would you mind posting a picture of it on the motor?
  16. #15
    Oct 2011
    Maple Valley WA
    Here you go...
  1. Shift Lever for Aftermarket Ignition Cover? (K2)
    By DE-Z50 in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 04-20-2014, 06:57 PM
  2. KLX/DRZ 110 shift shaft 05+ or quick shift and lever
    By braaap11889 in forum Bikes and Parts Wanted - All Makes
    Last Post: 11-07-2012, 08:06 PM
  3. Lifan 110cc engine - shift lever
    By chalkinblue in forum Z50, CT70 and JDM Monkeybikes
    Last Post: 10-19-2009, 06:41 PM
  4. wtb extended folding shift lever and brake lever
    By hondaboy101 in forum CRF50/CRF70 Parts For Sale
    Last Post: 11-12-2006, 11:06 PM
  5. WTB: Skidplate, footpeg mount, shift lever, engine dress up kit!!
    By BagdChevy in forum CRF50/CRF70 Parts For Sale
    Last Post: 04-15-2006, 05:01 PM
