Cracking Toast, Gromit! - Page 3
This is a discussion on Cracking Toast, Gromit! within the Honda Grom / MSX125 forums, part of the General Talk category; How did you do the stripe?...
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 158
Like Tree14Likes
Thread: Cracking Toast, Gromit!
  1. #31
    69z50's Avatar
    Dec 2011
    DFW
  2. #32
    69z50's Avatar
    Dec 2011
    DFW
    Tape?
  3. #33
    is a poet warrior.
    ShapeShifter's Avatar
    Sep 2008
    Vacaville, CA
    Yep yep. I got the stuff here: RED 12 TO 15 Inch Motorcycle Scooter CAR Wheel RIM Stripes 10mm Wide | eBay
    The ebay add says its from the UK but the seller ships from U.S. I bought from him because they were the cheapest but they are high quality. I am going to get some yellow ones from him too. I have some yellow plastics inbound.....
    The stripes come in segments and it takes about 3.5 segments each side of wheel. I use the "wet method" with Windex. Trying to put these on dry only gives you one chance to get it right. If you have to peel them off because thaey are not perfectly straight, it will bugger them.
    These are my mockups for mocking purposes.
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    I have the TT bracket but don't plan on putting it on until my low pipe comes. I removed the licence plate bracket and relocated the plate which cleans things up a little bit back there. I also removed the left bar end cap and installed an old mirror I had. The mirror base had to be cut to fit.
  6. #35
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    About that bar end cap - The stock end cap is held on with a wicked "lock bolt". I have never seen this kind of locking fastener.
    It is a fillips so that just makes removing all the harder without fukkin up the head of the bolt. You will need an impact screwdriver to remove it and you might need someone to help you hold the bars while you whack at the end of the impact driver with a hammer.
    The bolt has these helical cuts in it that are sort of barbed in the reverse direction so they grab real good. This is the reason you need the impact driver to get it loose. This also makes me think that the more you screw this bolt in and out, the more it is tearing up the threads in the hole....
  7. #36
    69z50's Avatar
    Dec 2011
    DFW
    I did the same thing with my license plate and front reflectors. Gonna do my TT and the low monkey pipe tonight.
  8. #37
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    Quote Originally Posted by 69z50 View Post
    I gott see how that other pipe fits on yours. If it fits, that changes my whole pipe plan.
  9. #38
    dave65721's Avatar
    May 2009
    SW Missouri
    On your mock up pic of the white bike there is a trellis looking frame section thing. Is that after market or just exposed and highlighted? I like your mock up for mocking purposes white bike best but prefer the headlight and pipe from the other.
  10. #39
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    Quote Originally Posted by dave65721 View Post
    I agree about the headlight. That will be addressed someday....
    The red trallis is from a picture of an aftermarket part I saw on ebay. Not part of the frame and would only add weight, besides cool looks.
  11. #40
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    When swapping the plastics, you will have many of these 6mm shoulder bolts. Beware that there are two different sizes but they look the same if you put them in a pile. There are two large shoulder 6mm that go on the small rearmost panel above the tail light. Al the other ones are the same.
    I got the plastics put on today, even though it is our 23rd wedding aniversery. My wifes gift to me was to let me play with my new toy. Love her! . Later on it will be all
    Here is a shot with the vintage Honda Monkey badges. I really kinda like this.
ID:	122809Click image for larger version.
    trk2ajk likes this.
  12. #41
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    Some notes on the Composimo Tail Tidy:
    The blinkers I am using are basic off the shelf ones from Cycle Gear. If you use these mini blinkers, you can fit them on without having to cut any of the stock bolts. No true if you are using the stock blinkers .
    The "correct" way to install the Composimo bracket is to put the nuts on top under the seat so that the heads are on the bottom. If you do it the other way, custom builders will say bad things about you.
    Also I suggest Composimo angle the licence plate bracket up slightly. Right now it is straight down, perpendicular to the ground and it just looks wrong on this bike. When viewed from the side, the license plate is the only vertical line on the bike. Lame.
  13. #42
    is a poet warrior.
    Sep 2008
    Vacaville, CA
    I am going to stick with the modern logos.
    PhilRabbleCroteau likes this.
  14. #43
    69z50's Avatar
    Dec 2011
    DFW
    Looks good!
    I lost a nut and washer down the subframe putting my TT on... Had to pick up the front end to dump them back out.
  15. #44
    is ...always lurking
    HondaFiddyMan's Avatar
    Dec 2009
    Cumming, GA (Atlanta area)
    Quote Originally Posted by ShapeShifter View Post
    <img src="http://planetminis.com/forums/attachment.php?attachmentid=122812"/>
    Great progress! I like either.
    -HFM
  16. #45
    is Going big or going home!
    Jordo's Avatar
    May 2012
    LancasterPA
    I freak'en LOVE the red pin stripe wheels. Nice touch!
    Quick question, are you running a low bend pipe to keep the heat off your ass, or do you like that style better?
    Hidden Content Originally Posted by Baker76 Hidden Content
    Ha that makes Jordo the god father of the full mod crf then...
  1. Is my KX65 hub toast?
    By Down2Mob in forum KLX110, DRZ110, TTR90
    Last Post: 01-24-2010, 02:51 AM
  2. Cracking cases?
    By Mike. in forum CRF50
    Last Post: 05-08-2008, 08:41 AM
  3. Any Solution to cases cracking??
    By MX81 in forum KLX110, DRZ110, TTR90
    Last Post: 12-14-2006, 09:15 PM
  4. A toast to everybodies weekend
    By skull52 in forum Off Topic
    Last Post: 04-14-2006, 05:38 PM
  5. cracking from loose spokes?
    By jdmp in forum CRF50
    Last Post: 01-08-2006, 02:58 AM
car painted white with gold flakes
composimo grom
daxdodo shipping review
grom exhaust
grom round headlight
honda grom mods
honda grom takegawa 143 kit
msx 125 mods small headlight
pearl white with gold flakes
round headlight honda grom
takegawa 143 grom
tricked out honda grom
