Seeking Grom fork dimensions - Page 3
This is a discussion on Seeking Grom fork dimensions within the Honda Grom / MSX125 forums, part of the General Talk category; Originally Posted by Suedehayes I am also putting grom forks on a ct70. The problem I ran into is the CT stem is longer.If you ...
Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Like Tree1Likes
Thread: Seeking Grom fork dimensions
  1. #31
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by Suedehayes View Post
    I am also putting grom forks on a ct70. The problem I ran into is the CT stem is longer.If you use the Grom lower triple with a CT stem the top clamp will not reach down to the top of the forks. Also the ride height is about 3 or four inches too tall. FYI the Grom forks centerline dimension is 204 mm.
    Well, we all knew that the stem was going to be too short, so that needs to be swapped. For the height, it might work out actually. The stock grom forks are way too soft. So, you can effectively shorten the grom forks and retain or slightly trim the stock springs and you should be in business. Problem is I don't know how far you can shorten the legs until they bottom out.
    I ended up using a set of ksr110 forks on one bike and a set of fastace forks on another. On both, I ended up sliding the forks up in the tree about 1/2" and then also adding 1" to the rear shocks. Work great!
  2. #32
    Suedehayes's Avatar
    Jun 2015
    Georgia
    Do you have any pics?
  1. Replies: 1
    Last Post: 03-04-2014, 10:13 PM
  2. Stock KLX110 fork spring dimensions & spring rate?
    By Orygun in forum KLX110, DRZ110, TTR90
    Last Post: 01-01-2014, 03:41 PM
  3. 37 USD Fork Internals Dimensions
    By Kurlon in forum Roost Area
    Last Post: 02-05-2009, 02:54 PM
  4. Desperately Seeking SP5 fork tube
    By bat999 in forum Bikes and Parts Wanted - All Makes
    Last Post: 01-15-2008, 02:14 PM
  5. Showa CR85 fork dimensions
    By Kurlon in forum Mini-Motards
    Last Post: 12-31-2007, 04:56 PM
fastace msx125
honda grom fork specs
