Seeking Grom fork dimensions
This is a discussion on Seeking Grom fork dimensions within the Honda Grom / MSX125 forums, part of the General Talk category; Can someone out here on the board please give me some dimensions of the Grom forks? 1. Clamping diameter at top 2. Clamping diameter at ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Like Tree1Likes
Thread: Seeking Grom fork dimensions
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    2. Clamping diameter at bottom
    3. Total length from top to axle center
    4. Axle diameter
    Info is greatly appreciated...thanks.
    storminnorman07's Avatar
    Nov 2005
    new castle, pa
    4. Axle diameter
    Si units or us customary?
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Quote Originally Posted by storminnorman07 View Post
    Didnt know they were different. Us versions then since those ate easy to get.
    Nov 2005
    new castle, pa
    Sorry I meant for measurements for you want inches or mm
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    MM is fine with me...
    Nov 2005
    new castle, pa
    Right on when I get out of class I'll pull some specs for you
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Awesome...any chance I can get you to throw a tape on it as well with a picture? know that's a lot to ask...but I do need to see where the taper is. On a honda ct70, the area for the lower clamping will be about 1.5"-2" lower on the fork tube than on a grom. So actually, can you make sure of that measurement as well please just in case the diameter is different?
    I was out running errands today and I went to the honda shop packing my caliper and they didn't have any groms on the floor. Then I went down to service and they didn't have one in for service either, otherwise I wouldn't ask...really appreciate it!
    Nov 2005
    new castle, pa
    Top clamp diameter
    Bottom clamp diameter
    Overall length of fork from top of fork to center of bolt
    I wasn't sure exactly how you wanted this measurement. I figured this view will be able to get you what you need to know by calcing if it's not right. Measurement is taken from top of the fork the start line is the beginning of the bottom clamp diameter and the end line is the end of the bottom clamp diameter
    You didn't ask for this measurement but figured it may be useful in calculating if my above picture isn't exactly what you where looking for.
    And lastly the diameter of wheel bolt is 12mm.
    Let me know if i kissed anything
  10. #9
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    This is exactly what i needed. Thanks so much...really appreciate it!
  11. #10
    Nov 2005
    new castle, pa
    No problem happy to help
  12. #11
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    don't happen to have a set of fastace sitting in a set of clamps do you? I need different dimensions from that one.
  13. #12
    swheels's Avatar
    Mar 2008
    Fayetteville Nc
    Don't know if this might interest you. There's some from forklegs on eBay.271853815791http://m.ebay.com/itm/HONDA-GROM-125-2014-15-FRONT-FORKS-TUBE-300-MILES-GREAT-CONDITION-/271853815791?nav=SEARCH
  14. #13
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    Chad...another question if you dont' mind. What is the offset of a standard fork setup? Also what are the dimensions of the inner to inner at the axle and inner to inner where the fork uppers and lowers come together at the tightest? A standard set of grom trees could potentiall work.
  15. #14
    is a member who doesn't care
    about a status.
    xr1million's Avatar
    Dec 2005
    Just south of hell, FL
    I like where this is going...
    Once my new Grom wheels come in I'll be building a set of clamps for Zoke forks.
    NAIL SLUTS, THEN RUTS ... then the slut again!
    N.S.T.R
  16. #15
    fatcaaat's Avatar
    Sep 2004
    Arlington, VA
    There's a couple of potential issues which is why I 'm doing all this research. First, the Grom forks do not look like they have much offset. Standard monkey/ct70 have 40mm and you can buy trees that have 55-60 which slightly extends the wheelbase and moves the tire forward so your bigger engines can clear. Another issue is height. Standard height of zokes is 730mm and not even sure if you can get 650mm anymore. That is way too long for a grom. A standard ct70 fork is 610mm.
    Reports of grom forks being too soft are all over, meaning you need to upgrade 300 bucks to make them work well. However, KSR110 forks are available and they are awesome with just adding 10wt oil and preload adjusters in 650mm. Still cost 600 bucks though
    Quote Originally Posted by xr1million View Post
  1. Replies: 1
    Last Post: 03-04-2014, 10:13 PM
  2. Stock KLX110 fork spring dimensions & spring rate?
    By Orygun in forum KLX110, DRZ110, TTR90
    Last Post: 01-01-2014, 03:41 PM
  3. 37 USD Fork Internals Dimensions
    By Kurlon in forum Roost Area
    Last Post: 02-05-2009, 02:54 PM
  4. Desperately Seeking SP5 fork tube
    By bat999 in forum Bikes and Parts Wanted - All Makes
    Last Post: 01-15-2008, 02:14 PM
  5. Showa CR85 fork dimensions
    By Kurlon in forum Mini-Motards
    Last Post: 12-31-2007, 04:56 PM
fastace msx125
honda grom fork specs
