SDG "A" Style Swinger
This is a discussion on SDG "A" Style Swinger within the Import/Chinese Parts for Sale forums, part of the Classifieds category; Well used SDG aluminum swinger...takes 15mm axle...disc brake...used in asphalt track racing so it has axle saver mounting holes...still has one saver still mounted.....needs one ...
Well used SDG aluminum swinger...takes 15mm axle...disc brake...used in asphalt track racing so it has axle saver mounting holes...still has one saver still mounted.....needs one inner bearing replaced (was missing when I got it) It is the black one in the pic...as you can see, it is probably +2 or +3...stock CRF50 is in the background
02-16-2009 10:38 AM
Re: SDG "A" Style Swinger
cheap swinga here...make offer
NEW PRICE...still make offer
How much are you wanting for it? How much for the big bike swinger in that picture?
Hows the trip going?
It's make offer Bro' the SDG swinger I think is +2 or +3...it has the inner sprocket side bearing missing (thats the way I got it) been painted black and has an axle saver on one side and drilled for one on the other side...was on a bike that was used strictly for asphalt racing......the big bike swinger is a +1 swinger from my Tech 5 Phantom frame....that is a really good item for a 10" bike...it uses 12mm axle and drum brake...I had it on my #65 bike in my album pics...as you can see in the pics, it did not look quite right with the Fastace forks and 12" front wheel........ride is goin smooth...still got a bit more to go...only bout 1/2 way done
$25 shipped in Cali....mas for elsewhere
kookoo 4 cocoa puffs bump
so will this mount up to a billetware cradle frame ?? and is all it needs is the bearing and it will work fine with the stock 50 rear wheel and drum break ? whats your price shipped to ontario canada
it uses disc brake and 15mm axle
how much shipped to 40045?
Originally Posted by
lado55
have you read everything about it in the posts?/?? if so, you can have it for $35 shipped
- You may not post replies
- You may not edit your posts
Forum Rules
