Jetting?
Jetting?
This is a discussion on Jetting? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a 134 piston and cylinder with a tb cam, ported head/intake, stock carb with the choke removed and a twobros adjustable needle. Also ...
Results 1 to 12 of 12
Thread: Jetting?
    MpR's Avatar
    Sep 2003
    Riverside, Ca.
    Jetting?
    I have a 134 piston and cylinder with a tb cam, ported head/intake, stock carb with the choke removed and a twobros adjustable needle. Also got a twobros pod filter.
    What jets should I run? Or what jets should I order and try out? Any help is appreciated.
    If it matters I can post up the dimensions on the in and ex port of the head.
    thanks.
    2wheeltyson's Avatar
    May 2005
    michigan
    Re: Jetting?
    you never mentioned a pipe. if it's aftermarket start around a 42pilot 90main or 95main.
    Busser90's Avatar
    Jun 2008
    Newtown, CT
    Re: Jetting?
    I cant garentee anything, but im running the same set-up. 134 tb cam, stock carb w. choke taken out, along with a stock exhaust..
    Do you have any topend or what??
    I have bottom and mid but no top.. i have a 38 pilot and a 78 or 80 main.. Im stumped. im just lookinto get a VM26MM
    But if you find out a mint jetting, PM me and let me know.. this no topend is F'N killin me!!
    69z72r's Avatar
    Jul 2008
    york, PA
    Re: Jetting?
    what does the choke removal do?
    May 2005
    michigan
    Re: Jetting?
    let more air thru with less turbulance. but get a pancake filter so you can still manually choke your bike.
    robbieyukon's Avatar
    May 2007
    Maryland 20853
    Re: Jetting?
    i'm running a 134. ported stock head, tb cam, no airbox, and mod-stock exhaust. i'm running a 42/90 jet setup. I would try running the next step up on the main if I were you. i'm also a couple some hundred feet above sea level. great bottom and mid-range, no top.
  7. #7
    pete sassano's Avatar
    Dec 2008
    Lakeview, Michigan petesassano@yahoo.com
    Re: Jetting?
    I would definetly try a bigger main, sounds like its not getting enough fuel.
  8. #8
    j440's Avatar
    Oct 2007
    CT
    Re: Jetting?
    i ran a 134, and cam with everything else stock, with stock jetting, then i put in a 40 pilot, that helped. after that i just put on a 26mm carb and haven't looked back.
    but i would try 40, 42 pilot, and a 85 main. then adjust the needle accordingly.
    also fine tune your a/f screw.
  9. #9
    MpR's Avatar
    Sep 2003
    Riverside, Ca.
    Re: Jetting?
    thanks guys, I think Im going with the 42 pilot and 95 main. I believe it has an 85 main in it now and its not enough. I have a dr. d exhaust on it too.
  10. #10
    dood's Avatar
    Sep 2006
    Washington
    Re: Jetting?
    it's your the pan cake style air filter.
    High RPM, the filter will suck into the carb and restrict the flow, hence no top end.
  11. #11
    May 2007
    Maryland 20853
    Re: Jetting?
    What about the filters that have the spring coil inside the foam, do they suck into the carb too?
  12. #12
    dood's Avatar
    Sep 2006
    Washington
    Re: Jetting?
    It depends on the size of the engine and head but yes, I have seen even the ones with the springs inside suck into the carb.
    Usually small engines like yours don't have that issue, but it can still happen.
klx110 jetting pancake filter and pipe mod
