TTR 90 idle/ carb adjst.
This is a discussion on TTR 90 idle/ carb adjst. within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; 1) What would cause a delay in the bike returning to idle after the throttle is released,the bike seems to want to run on. 2) ...
Results 1 to 3 of 3
    glassman's Avatar
    Jan 2009
    1) What would cause a delay in the bike returning to idle after the throttle is released,the bike seems to want to run on. 2) I'm looking for the carb. adjustment settings(exterior only-no jetting). I think there's (2) screws to adjust besides idle. Thanks
    is building them fast &
    racing them faster
    badmatt828's Avatar
    Jan 2007
    Whisky Rapids, WI
    Re: TTR 90 idle/ carb adjst.
    Quote Originally Posted by glassman
    Bad cable or dirt in the throttle. Stock carb has idle and air screw the idle s the bigger one of the two and is in the middle of the carb the air screw is the one by the air cleaner boot.
    glassman's Avatar
    Jan 2009
    Thanks, I found an adjustment setting for the small screw(air) on another site, but was not sure exactly which screw it was until I got your reply. It said to lightly seat the screw and back out 1-1/2 turns. Also, about the idle, I'm going to take the air boot off and make sure the slide is coming down as quick as the throttle is released. Thanks again.
how to adjust carb on ttr 90
how to adjust idle on ttr-90
how to adjust ttr90 carb
ttr 90 air screw
ttr 90 air screw setting
ttr 90 carb adjustment
ttr 90 carburetor adjustment
ttr 90 idle adjustment
ttr90 carb settings
ttr90 throttle screw
yamaha ttr 90 carburetor adjustment
yamaha ttr 90 carburetor idle adjustment
