-=| No Spark KLX110, Checked Kill Switch and Neutral Switch, Still Nothing... |=-
This is a discussion on -=| No Spark KLX110, Checked Kill Switch and Neutral Switch, Still Nothing... |=- within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Well as my luck has it not only is my mod110 not running, but now the stocker just took a ****. It's just a stock ...
Results 1 to 8 of 8
    cmktech's Avatar
    Feb 2006
    Nor-Cal, CA
    but now the stocker just took a ****. It's just a stock head 134cc with cam, stock carb.
    It was running fine for a couple hours, and then when I went to go back out I kicked it over and nothing.
    No spark.
    Now, I exchanged kill switches between bikes, tried installing a bump start, nothing. Installed another oem neutral switch, and still nothing.
    Anyone have experience and know what this means?
    Stator, CDI, Coil, and wiring harness are left to check, but this bike has been bullet proof until now....
    Thanks to my 2007 sponsors:
    -Shift Mx
    Tg
    Tg is offline
    Tg's Avatar
    Nov 2008
    RIVERSIDE
    Re: -=| No Spark KLX110, Checked Kill Switch and Neutral Switch, Still Nothing... |=-
    when my engine just got done being built it didnt have spark either. i tried basically everything u did plus switched the stator still nothing.
    i bought a new spark plug, disconected all wireing, cleaned all connections, cleaned the conection to ground on the frame put it all back together and it had spark.. thats just what happened to mine dont no if it will help. good luck
    is dab'd out
    stunt-ur's Avatar
    Feb 2007
    Houston, TX
    Gotta check everything! Replace all your electrical piece by piece if you have it available to narrow down the options.
    Luckystar64's Avatar
    Feb 2007
    Brunswick, Ohio
    Check the pickup down by the stator, my bike went limp in the middle of a race after a great start! I was so pissed! I thought it fouled a plug, but after I switched every piece of electrical equipment with my stocker, I pulled the stator cover off, and a screw on the pickup backed out and made the pickup lose contact with the stator... I screwed it back in, and my bike ran fine. --L*64
    Feb 2007
    Brunswick, Ohio
    Oh! One more thing... if you're running a bump start, that could be the culprit, or the contact by where the bump start goes could be not contacting properly. --L*64
    cmktech's Avatar
    Feb 2006
    Nor-Cal, CA
    OKay guys help me narrow it down......
    I went and swapped the motors...
    THe motor that would NOT fire (had no spark) in the klx110 fired up and runs fine in the drz110 (stocker).
    Now, that means it can't be the neutral switch, stator, or the kill switch because they work and I swapped the kill switches and bump starts before anyways.
    Does that mean it's either the coil, the harness itself, or the ground?
    -Shift Mx
  7. #7
    50WHIP's Avatar
    Apr 2005
    INDIANA PA.
    I vote ground ,seen it a bunch of times.
  8. #8
    bonez1093's Avatar
    Jun 2008
    new york
    if you take the coil and the cdi box from the stocker and try them one at a time on the klx you might find its one of them...if not you can narrow down to a ground
06 klx 110 not firing
2006 klx110 no spark
how to check a klx 110 coil
how to test a spark plug coil on klx110
if klx 110 kill switch is loose on bars will the bike still start?
klx 110 2007 not firing
klx 110 ground neutral switch
klx 110 no spark
klx 110 not starting swap
klx 110 pickup coil
klx110 no spark
no spark on my drz 110
