Need help with a few questions?
This is a discussion on Need help with a few questions? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; #1-how do you know if you main jet is too big? I have a Tak 138 with a race head and 26mm carb. I put ...
Results 1 to 4 of 4
    bstory1968's Avatar
    Apr 2007
    Forney, TX
    #1-how do you know if you main jet is too big? I have a Tak 138 with a race head and 26mm carb. I put a 190 main and a 22.5 pilot. it seems to run fine but seems like it is getting to much gas. It did have a 170 Main and a 25 pilot.
    #2-fork help. it has stock forks with heavy duty springs. My 10 year old will be racing it and the forks are too stiff even for me at 180lbs. should i just try changing the oil, or can the springs be cut a little? If they can be cut, how much do you cut? Stock spring are not enough.
    bstory1968's Avatar
    Apr 2007
    Forney, TX
    Re: Need help with a few questions?
    Can anyone help me with these questions?
    BBR Motorsports's Avatar
    Feb 2009
    Auburn, WA, USA
    # 1
    Typically if your main is too big it will "surge" on top-end. And if you let of the throttle just a bit it will actually run better. When it "pops" or back fires on top-end you are too lean.
    # 2
    DO NOT cut your springs. This will make them much stiffer and not help with your set-up. For your lighter rider I would try one HD spring and one OEM spring with 5 or 10 wt oil, 155cc per leg. For you I would try one HD and one OEM spring with 15 or maybe even 20 wt oil, 170cc per leg.
    BBR Motorsports
    bstory1968's Avatar
    Apr 2007
    Forney, TX
    Thank you very much.
    THis bike is for my 10 year old and he weights about 75 lbs. So use one fork with a stock spring and the other with a HW Spring? 5 or 10 wt. oil 155cc? I was told to use Transmission fluid and a lighter weight oil.
    I will have him try the throttle and see if it does what you said on the top end.
