oil in pipe
This is a discussion on oil in pipe within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; alrightyy by now some of you know my bike was leakin some oil this weekend due to the valves on the head (we think) anddd ...
Results 1 to 4 of 4
Thread: oil in pipe
    midgetbmxer's Avatar
    Dec 2007
    San Diego, CA
    oil in pipe
    alrightyy by now some of you know my bike was leakin some oil this weekend due to the valves on the head (we think) anddd now i got a bunch of oil left in my pipe... soooooo i was hopin some of you had some ideas to how i can clean that..
    if i cant clean it.. then im going to buy a yoshi pipe and sell the FMF i have.. maaaaaaaan those yoshi carbon pipes look sick as hell!
    is embracing El Nino in the NW.
    squidwell's Avatar
    Apr 2006
    Beervana
    Re: oil in pipe
    if it's only in the header try some gas or carb cleaner if it's reached the can I'd say the packing should be replaced then after can is cleaned
    2wheeltyson's Avatar
    May 2005
    michigan
    Re: oil in pipe
    just dump the oil and let the header hang overnight. dont worry about the small amount coating the header it'll burn off during the first ride.
    Z50King's Avatar
    Sep 2004
    Upland, Ca, CPP
    Re: oil in pipe
    yes, take it off and hang it can end up
    if your packing is soaked, you should be able to replace it, unless the cap is rivoted on. if it is, fmf can replace it for you
klx110 packing oil soaked
