Aftermarket OutPut Shaft - Page 2
This is a discussion on Aftermarket OutPut Shaft within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; hey j440 what happened to my messages not getting responded to?? AND my cradle and my upper shock moutn???...
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 54
  1. #16
    twosmoke30's Avatar
    May 2009
    Re: Aftermarket OutPut Shaft
  2. #17
    rcorrigan330's Avatar
    Mar 2009
    medina, OH
    yo guys u think its my output shaft if i go to kickstart and it just makes a grinding noise? pre-2008 model
  3. #18
    DBomb456's Avatar
    May 2009
    what's an output shaft? is that like a drive shaft? are there drive shaft pit bikes? or is this for an electric motor?
  4. #19
    Bri
    Bri is offline
    Bri's Avatar
    Apr 2007
    Danville,Iowa
    Quote Originally Posted by rcorrigan330
    probably cuz that's what mine did and when i took off the side cover the part that broke fell out!!!!!!
  5. #20
    Mar 2009
    medina, OH
    nothing really felll out. okay maybe it did i honestly have no idea what it was tho i found a bearing figured out where it went but there was this little ring.. ? idk where it came from maybe over the bearing? idk i should be ordering my output shaft as soon as my check goes thru.. sucks bein broke
    fixing my bike then selling it
  6. #21
    is an asshole
    chasetheface123's Avatar
    Nov 2007
    Boyne City Michigan
    Quote Originally Posted by bbrklx110
    wait so if im running a 195 do i need to upgrade the ouput shaft on my 06klx110?jk
    Nope your good. You need a motor that puts out some power before you do it. My stocker 50 would smoke that thing off the line.
  7. #22
    kman153's Avatar
    Aug 2008
    boston
    i havent had a problem with my 05 but im just running a mod stocker
  8. #23
    KLX110RACING's Avatar
    Jan 2007
    U.K
    Which aftermarket output shaft do you guys recommend.
  9. #24
    is BRAAAP!
    Frank21x's Avatar
    Mar 2009
    Lodi, California
    I've heard on here quite a bit the stock '08 shaft works just fine and is more than half the price of either BBR or CHP's billet shafts.
    Kawi '08 shaft- $50-60
    BBR- $160
    CHP- $180-190
  10. #25
    Cokeham's Avatar
    Oct 2009
    Arlington, Texas
    will an 08+ output shaft fit in my 05?
  11. #26
    Busser90's Avatar
    Jun 2008
    Newtown, CT
    it will.. the 08 shaft fit my 02 i had. same cases
  12. #27
    michael109's Avatar
    Mar 2008
    Lancaster
    tbparts.com has them for $59. are they easy to change???????
  13. #28
    is oredered my backgroubds and
    graphix for Vegas can't wait
    to get them
    klxadogg437's Avatar
    Feb 2009
    K-Tizzy,Oregon
    Quote Originally Posted by chasetheface123
    That is good times right there!
  14. #29
    lightle09's Avatar
    May 2010
    Yuba City, California
    i just bought a new bbr output shaft. Are they hard to install
  15. #30
    lightle09's Avatar
    May 2010
    I just bought a bbr output shaft. Are they hard to install
aftermarket output shaft for kawaski klx 110
biggerminisforbiggermen.com
drz 110 output shaft seal
drz gear shaft
klx 110 broken shaft repair
klx 110 grinding noise
klx 110 install output shaft
klx110 out put shaft stock vs after market
klx110 output shaft
output shaft 08 klx110
suzuki drz110 output shaft
where to get a klx110 output shaft uk
