Aftermarket OutPut Shaft
This is a discussion on Aftermarket OutPut Shaft within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; is it right in there near where ud but in the 4th gear? i hear its best to do both same time.. also what are ...
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 49 of 49
  1. #41
    mx.rida's Avatar
    May 2009
    San Diego
    Re: Aftermarket OutPut Shaft
    also what are all the parts ill need? what gaskets? seals? and any other things?
    thank you
  2. #42
    Gargedog's Avatar
    Dec 2010
    I am tearing down my motor that has had the cases split, but I don't really no the history on the motor. How can I determine if the motor has the stock output shaft or an aftermarket. Casting numbers are shaft measerement sizes? My motor Is an 06,
  3. #43
    ma71t's Avatar
    Dec 2010
    Same question here, I recently bought a 2002 with a 134 kit in it and the thing rips but I'm worried about the shaft and was wondering this same thing the other day??
  4. #44
    is www.facebook.com/888.christian
    Pitbiker888's Avatar
    Jun 2008
    Germany (Saxony)
    I ride a 2003 DRZ110 and installed the 08 kawa output shaft. And it broke! Where is the difference to the bbr output shaft?
  5. #45
    HarryKlx's Avatar
    Apr 2011
    i think i broke my output shaft. When I try to start it, the kickstart lever slips to the bottom of the stroke. I took the clutch cover off and I can see the end of the out put shaft. it spins freely and slides in and out about a half inch... the kick start gear seems fine, the clutch seems fine. I know I will need seals and gaskets but I can buy a gasket set for $30.
    How hard is it to change the output shaft?
    Anyone know a site that sells good ones for cheap?
  6. #46
    DUANE290's Avatar
    Mar 2007
    JACKSON CENTER PA
    Bbr shaft comes with first gear
  7. #47
    cozi70's Avatar
    Jun 2009
    Northern ireland
    Here's a ksr I've had to work on recently. Fitted with a 143cc kitaco kit. The kickstart started to slip badly,then just stopped engaging altogether .
    Upon strip down the famous pre2007 broken output shaft and damaged low ratio gear bush were found.
    Now rebuilt and running well
  8. #48
    DRZdill's Avatar
    Oct 2012
    xenia, ohio
    Just throwing this out there.
    TBoltUSA makes a nice forged output shaft. Only $70
  9. #49
    goinsriding's Avatar
    May 2012
    I read this thread and no one said if the output shaft with the first gear forged on it made a difference or not. Does it?
06 klx110 counter shaft
aftermarket output shafts
biggerminisforbiggermen
biggerminisforbiggermen.com
countershaft kitaco
how expensive is output shaft repair on klx110
how much repair output shaft broken klx110
klx 110 grinding noise
klx110 counter shaft install
new output shaft install for bike
ttr 90 output shaft
www.biggerminisforbiggermen.com
