Aftermarket OutPut Shaft - Page 4
This is a discussion on Aftermarket OutPut Shaft within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Bbr shaft comes with first gear...
Page 4 of 4 FirstFirst ... 234
Results 46 to 54 of 54
  1. #46
    DUANE290's Avatar
    Mar 2007
    JACKSON CENTER PA
  2. #47
    is Chillin like a villain
    cozi70's Avatar
    Jun 2009
    Northern ireland
    Here's a ksr I've had to work on recently. Fitted with a 143cc kitaco kit. The kickstart started to slip badly,then just stopped engaging altogether .
    Upon strip down the famous pre2007 broken output shaft and damaged low ratio gear bush were found.
    Now rebuilt and running well
  3. #48
    DRZdill's Avatar
    Oct 2012
    xenia, ohio
    Just throwing this out there.
    TBoltUSA makes a nice forged output shaft. Only $70
  4. #49
    goinsriding's Avatar
    May 2012
    I read this thread and no one said if the output shaft with the first gear forged on it made a difference or not. Does it?
  5. #50
    NickRoth620's Avatar
    Jun 2013
    shittt.. i should have bought an 08.......
  6. #51
    is 2010 klx110 Stock Mod
    SikkMx108's Avatar
    Sep 2011
    Long Island, NY
    I bought a used 2010 110 and the guy installed a T-Bolt clutch system. The whole clutch case was replaced so you think the output shaft was replaced?
    Sorry to ask, but what exactly is a output shaft and why do the stockers tend to break.
  7. #52
    Petersen112's Avatar
    Jan 2010
    McHenry, IL
    Theres a hole to let oil by in old output shafts that would break under pressure from kickstarting. The only way to replace it is to split the middle cases (not the clutch cover). But it was updated on 08 and newer bikes to the hd one so you are all good, you already have a good one.
  8. #53
    Domcorleone420's Avatar
    Apr 2016
    Ca
    Quote Originally Posted by DBomb456 View Post
    what's an output shaft? is that like a drive shaft? are there drive shaft pit bikes? or is this for an electric motor?
    Same question here. Id like to know what it does not just buy one.. anyone answered this?
  9. #54
    Yagatogi's Avatar
    Apr 2015
    Cali-AZ-LV
    Its part of your transmission and not really needed unless you plan on instaling a big bore kit.
aftermarket output shaft for kawaski klx 110
biggerminisforbiggermen.com
drz 110 output shaft seal
drz gear shaft
klx 110 broken shaft repair
klx 110 grinding noise
klx 110 install output shaft
klx110 out put shaft stock vs after market
klx110 output shaft
output shaft 08 klx110
suzuki drz110 output shaft
where to get a klx110 output shaft uk
