Aftermarket OutPut Shaft
This is a discussion on Aftermarket OutPut Shaft within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; YES, you should get one whether it be the new stronger oem one, or an aftermarket one. pre 08 output shafts suck and break at ...
YES, you should get one whether it be the new stronger oem one, or an aftermarket one. pre 08 output shafts suck and break at the oiling hole. I have broken them on stock bikes and 143 bikes. Ridden easy or ridden hard...No more questioning if you need it with this or that motor...Yes you need it or it will break when you need it most guaranteed.
04-07-2009 08:52 PM
Re: Aftermarket OutPut Shaft
good thread all these people that are talking about it in 5 different threads just read this and to be safe just get one..spend now or spend more later..up to you guys
but how much what kind of oil should be used?........8*)
doesn't matter how many times you post this...without stickies it will be asked over and over again....hell even with stickies it will probably asked but thats what kids do.
did you accidentally hit new thread instead of reply?
Originally Posted by
Blackwoodz
yea but definitely help out being a sticky. i personally think an output shaft and 4th gear drum should be the first thing done to a 110 even if its completely stock considering ive broken one on a completely stock 110
no, ive seen like 5 output shaft threads in the last day. So i posted this and hopefully people see it if they search before posting, or see it and dont post.
got ya.. i was just reading the other one about the 143.. so i thought you were reading that and replied with a new thread haha.
this should be sticky'd for sure though
no dont sticky it just put it with all the information of a 110 sticky
so if i have a 08 im good?
JBlanchard23
yes they updated the 08+
been there done that.. snapped one on my 134
wait so if im running a 195 do i need to upgrade the ouput shaft on my 06klx110?jk
where do you get one and and how much.. and after buying one i wont have to worry about it breaking ever again?
biggerminisforbiggermen.com should have exactly what your looking for minimoto. hope this helps
yo if my engine wont turn over and makes a grinding noise u think its the 06 output shaft tht effin sucks lol
hey j440 what happened to my messages not getting responded to?? AND my cradle and my upper shock moutn???
yo guys u think its my output shaft if i go to kickstart and it just makes a grinding noise? pre-2008 model
what's an output shaft? is that like a drive shaft? are there drive shaft pit bikes? or is this for an electric motor?
rcorrigan330
probably cuz that's what mine did and when i took off the side cover the part that broke fell out!!!!!!
nothing really felll out. okay maybe it did i honestly have no idea what it was tho i found a bearing figured out where it went but there was this little ring.. ? idk where it came from maybe over the bearing? idk i should be ordering my output shaft as soon as my check goes thru.. sucks bein broke
fixing my bike then selling it
- You may not post replies
- You may not edit your posts
Forum Rules
06 klx110 counter shaft
aftermarket output shafts
countershaft kitaco
how expensive is output shaft repair on klx110
how much repair output shaft broken klx110
klx 110 grinding noise
klx110 counter shaft install
new output shaft install for bike
ttr 90 output shaft
www.biggerminisforbiggermen.com
