my 143 kit is burning oil to the point where it smokes pretty bad and my pipe is always wet.... ne ideas?
I infidel 2334 posts · Joined 2007 Add to quote Only show this user #2 · Jun 6, 2009 rings or valve seals bye bye
D drz143 Discussion starter 8 posts · Joined 2009 Add to quote Only show this user #3 · Jun 7, 2009 but its a brand new build
I infidel 2334 posts · Joined 2007 Add to quote Only show this user #4 · Jun 7, 2009 ring gaps line up together?
G Unknown member Add to quote #5 · Jun 8, 2009 ring gaps lined up? they should be opposite of each other.
nemec 18 posts · Joined 2008 Add to quote Only show this user #6 · Jun 9, 2009 the same problem I have. Smoke is wihte/light grey
way2fast4u7 339 posts · Joined 2008 Add to quote Only show this user #7 · Jun 9, 2009 is there a chance that the gaps on your rings are all close to lined up? that would be a good explination. or you have rings with a messed up end gap. could be possible. other option is that you have bad valve seals.
9 96Justin 1100 posts · Joined 2009 Add to quote Only show this user #8 · Jun 9, 2009 pull it apart and take pictures you'll find out quick where the leak is coming from
