143 kit, head work,.... what clutch setup do I need?
This is a discussion on 143 kit, head work,.... what clutch setup do I need? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I just bought 143, inner rotor, cam, carb, pipe, port & polished head, big valves... I don't know really right now what clutch setup that ...
Results 1 to 5 of 5
    BrandXMinis's Avatar
    Aug 2005
    Sunbury, Ohio
    I just bought 143, inner rotor, cam, carb, pipe, port & polished head, big valves... I don't know really right now what clutch setup that I need. I have heard to just get 2 more stock springs and that is the same as the heavy duty kits.
    Then also, where is the best place to get the manual clutch itself?
    Aug 2005
    Sunbury, Ohio
    Also, I have heard of a couple things to make it fully manual, what do I need for that and where? Sorry for all the questions
    MpR
    MpR is offline
    MpR's Avatar
    Sep 2003
    Riverside, Ca.
    check ebay frequently, the usually have a guy who sells the hydroclutch with the manual conversion and hd clutch springs, it generally goes for uder 300, 280 area.
    jumpinjohnny's Avatar
    Dec 2004
    use kx65 clutch fibers and springs works the best no slipping on my crower 160
    JUMPIN JOHNNY
    Aug 2005
    Sunbury, Ohio
    Ok, I'll try that out. Are you using the Takegawa primary drive gear or are you just using the 2 bros washer thing on your setup if your running the manual clutch?
