4th gear
This is a discussion on 4th gear within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; Do you need to split cases to put the 4th gear drum in? And how hard is it?...
Results 1 to 12 of 12
Thread: 4th gear
    Factory110's Avatar
    Dec 2009
    Uxbridge, Ontario
    4th gear
    Banned
    firepower354's Avatar
    Oct 2006
    Flint MI
    Re: 4th gear
    Yes. The entire motor needs to come apart, for the most part. You can leave the crank and trans in the left case half, so it saves a few steps, but it's no cake-walk. Getting the OE case sealant all out without complete gutting is tough.
    Factory110's Avatar
    Dec 2009
    Uxbridge, Ontario
    Re: 4th gear
    ok well i already have the topend off and just doing this since ive got it torn down. I have a service manual, and i guess taking photos will help aswell. Do you have any other suggestions to put in while they are split and Im going to need a new gasket correct.
    Banned
    Oct 2006
    Flint MI
    Re: 4th gear
    Quote Originally Posted by Factory110
    There's no center gasket, but you'll likely need a clutch gasket, and of course the top end set. If it's an '07 or older, you'll want an output shaft. Shame to have it that far apart and not bore the cases for later upgrades, and toss in a stroker crank
    Factory110's Avatar
    Dec 2009
    Uxbridge, Ontario
    Re: 4th gear
    lol its an 06 and ive got a tb165 kit going in so i have the headgaskets. Besides the stroker crank how much is a outputshaft
    Banned
    Oct 2006
    Flint MI
    Re: 4th gear
    $59, with free shipping for the output shaft.
  7. #7
    5nine8's Avatar
    Jan 2007
    Mendota, IL
    Re: 4th gear
    Also if you stroke it w/ the 165 kit you'll need to bore the cases
  8. #8
    mo-tarded's Avatar
    Nov 2007
    Allen, TX
    Re: 4th gear
    Quote Originally Posted by firepower354
    You have to use sealant....
  9. #9
    redirt78's Avatar
    May 2009
    Dry Branch, Georgia.... off in the cut
    Re: 4th gear
    get a manual clutch (if you dont already have one) and buy my new, never used c.f. primary gear (if you dont already have one)
    $75 shipped
  10. #10
    ja564rm80's Avatar
    Jan 2008
    Mt. Morris
    Re: 4th gear
    bud u DEFF need the output shaft! or u will be splitting the cases again after one kick
  11. #11
    Factory110's Avatar
    Dec 2009
    Uxbridge, Ontario
    Re: 4th gear
    Other than just taking my time and taking photos, with my service manual is it not that hard to do?
  12. #12
    Factory110's Avatar
    Dec 2009
    Uxbridge, Ontario
    Re: 4th gear
    for an outputshaft would just getting a 2009 oem shaft be fine?
