55mm stroker crank?
55mm stroker crank?
This is a discussion on 55mm stroker crank? within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; so can that pig can be put into any big bore kit? im thinking about doing a tb 143 kit with race head just wondering ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    gfisher's Avatar
    Mar 2010
    taxachusetts, 01475
    55mm stroker crank?
    so can that pig can be put into any big bore kit? im thinking about doing a tb 143 kit with race head just wondering if i could place one of those cranks in with it....
    is Double Truckin' the Tricky Two
    BaBy!
    XLr8r's Avatar
    Apr 2007
    Muddin'
    Re: 55mm stroker crank?
    Stroke that thang out to a 155.
    While you're in there, put in a forged output shaft, CHP's 2nd gear & shift star, and a 4th gear shift drum.
    BIERDZY262's Avatar
    Jul 2009
    South Bend IN
    it will work but make sure you put in a aftermarket output shaft. The stroker will cause some much compresion that shaft will snap and break when you try to kick it over. since your splitting the case put in a 4th gear as well.
    gfisher's Avatar
    Mar 2010
    taxachusetts, 01475
    alright thanks guys, sounds good
    tweakeds10's Avatar
    Nov 2008
    CT
    Quote Originally Posted by XLr8r
    Exactly everything I went with, and a few extras.
    Stroked 143 (155)
    TB 143 kit w/ 26mm carb
    TB 55mm Stroker
    TB 4th Gear Shift Drum
    08+ Heavy Duty Output Shaft- already installed
    CHP Shift Star
    CHP 2nd Gear
    Kitaco Heavy Duty Clutch Springs
    Engine Hardware Kit
    Heavy Duty Head Bolts
    New Gaskets, seals, etc.
    Stock air box removal bracket
    BBR U-flow Intake
    FRD EZ D-Compression Valve- helps tremendously!
    Manual Clutch highly recommended. Bike absolutely rips now. Had to upgrade to KX65 brakes front and back just to be able to stop the damn thing!
    tweaked
    gfisher's Avatar
    Mar 2010
    taxachusetts, 01475
    Quote Originally Posted by tweakeds10
    Stroked 143 (155)
    TB 55mm Stroker
    CHP Shift Star
    CHP 2nd Gear
    Engine Hardware Kit
    BBR U-flow Intake
    tweaked
    hope you dont mind tweaked, but im most likely going to do the same exact set up as you. everything you have in yours i have been looking at over the past couple weeks haha
  7. #7
    tweakeds10's Avatar
    Nov 2008
    CT
    Quote Originally Posted by gfisher
    Not a problem, and I'm not that unique. Just waiting to mount the black rear rim and get some final pics. Recently mounted the STR front galfer rotor for the KX65 brake. Just need to order a galfer rotor for the rear to finish of the look. After that basically finished. 12K later lol.
    tweaked
  8. #8
    gfisher's Avatar
    Mar 2010
    taxachusetts, 01475
    tweaked
    dang man, 12g stacks? haha thats nuts, i dont think ill go that crazy but maybe like 10 grand less haha
  9. #9
    brink444's Avatar
    Oct 2008
    Irvington, IL
    Damn 12g's?? I just bought a brand new 09 and have literally replaced everything except the frame and I dont think im even close to that..
  10. #10
    Jason Eden's Avatar
    Apr 2009
    If you run the strocker dont you need to bore your cases?
  11. #11
    BaBy!
    XLr8r's Avatar
    Apr 2007
    Muddin'
    No case boring necessary for a "strocker" crank. Only if you put in a big bore kit with a skirt (or spigot) that's larger than stock.
  12. #12
    tweakeds10's Avatar
    Nov 2008
    CT
    I had Chaplin Kawasaki bore it anyway so whne I'm ready for the bigger kit- it will go right in.
    And yes, I have put way too much money in it. Bought it new in 2008 for my wife, and fell in love. Sold my big bike and dumped that plus more money into it. I'm obsessive, and love when you can make something so unique!
    tweaked
  13. #13
    FASTFREAK693's Avatar
    Nov 2006
    SWANSEA, MASS.
    tweaked
    I ran that 155 engine combo last season and it ripped! It's also very reliable. I ran mine all season with 0 problems, just changed the oil every ride and adjusted the valves a couple times.
    Ever ride at MX691? That bike and truck look familiar......
  14. #14
    gfisher's Avatar
    Mar 2010
    taxachusetts, 01475
    im glad to see that this set up is very reliable because thats exactly what im looking for, something that rips and will start everytime i need it too. ive used my 110 as transportation back and forth to party's in the pit near my house for a couple years now haha but im looking to actually get into racing these things
  15. #15
    Gixxer1K87's Avatar
    Oct 2008
    Minneapolis
    Sounds like a DUI waiting to happen.
143 big bore woth storker crank
55 mm stroker crank klx 110
ass kicking crank shalf for gy6 scooter chinece
klx 110 143 big bore kit with 55mm stroker crank
klx 110 big bore strocker
klx 55mm stroker crank install
klx110 55mm stroker
klx110 stroker crank
klx110 stroker kit
kx65 stroker crank
should i get a stroker or a bigger big bore kit klx110
stroker kit kx65
