bike wont start
This is a discussion on bike wont start within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I dont no why it wont start i used carb cleaner checked the plug its good i pluged a good kill switch to it and ...
Results 1 to 11 of 11
Thread: bike wont start
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    bike wont start
    I dont no why it wont start i used carb cleaner checked the plug its good i pluged a good kill switch to it and i know its good but nothing happens o and i cleand the idel screw anything will help
    thanks mike
    Gixxer1K87's Avatar
    Oct 2008
    Minneapolis
    Re: bike wont start
    You will probably need to provide a bit more info, what did you do to cause it to not start, if anything?
    Also, what is it doing when you kick it over? Does it act normal just doesn't sound like its going to fire? How old is the gas, has it been sitting? Check for spark, check to make sure you don't have a blocked fuel line/jet or anything then double check the kill switch.
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    Re: bike wont start
    ya thats the problem its ben siting it sounds like it wants to go but ill check
    the fuel line
    is Baller on a Budget!
    locojo25's Avatar
    Apr 2009
    Mount Morris, N.Y.
    Re: bike wont start
    Once again I would pull the plug check spark its prolly the neutral safety switch
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    Re: bike wont start
    fuel line is good was wondering if the coil could be bad
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    Re: bike wont start
    were is that at
  7. #7
    locojo25's Avatar
    Apr 2009
    Mount Morris, N.Y.
    Re: bike wont start
    black switch down by the front sprocket cut the light green wire put an electrical terminal on it and ground it to an engine bolt then it will also be able to pop start it as well! always a good thing to do right off the bat cuz they seem to fail on everyones bike!
  8. #8
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    Re: bike wont start
    ok thanks ur a big help
  9. #9
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    Re: bike wont start
    what should i do to the dark green wire should i plug it back in
  10. #10
    mk_dauphin's Avatar
    Jul 2008
    Belleville IL
    Re: bike wont start
    still wont fire
  11. #11
    Gixxer1K87's Avatar
    Oct 2008
    Minneapolis
    Re: bike wont start
    If its been sitting you probably need to clean ur carb and replace the gas. Check out the jets and make sure they are clear then hose the thing down with carb cleaner. Check the spark before this, pull the spark plug out of the head (leave it plugged in and hold the end of it next to the threads for the head or a bolt and watch for spark.
