Rear drum brake problem
This is a discussion on Rear drum brake problem within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; The rear drum brake on my DRZ110 always seem to stick when ever I use it, I oiled and greesed every part of the linkage, ...
Results 1 to 15 of 15
    drz63's Avatar
    May 2010
    Corona, CA
    The rear drum brake on my DRZ110 always seem to stick when ever I use it, I oiled and greesed every part of the linkage, but after about a half hour of riding it will start to stick again. I know a disc brake would solve the problem, but is there anything I could do to fix the problem with drum untill I switch to a disc?
    coolaaaa's Avatar
    Oct 2009
    Jersey Shore
    Re: Rear drum brake problem
    check the brake pedal itself, the shaft it rotates on could be corroded. Use "never seize" on it, and the brake cam shaft, which also could be corroded.(common problem)
    drz63's Avatar
    May 2010
    Corona, CA
    I've checked both of those and both parts move freely
    coolaaaa's Avatar
    Oct 2009
    Jersey Shore
    Quote Originally Posted by drz63
    check the drum measurement (ID). It may be worn out., or maybe it is scored?
    crawl779's Avatar
    Apr 2010
    It just means it time for new brake shoes....
    drz63's Avatar
    May 2010
    Corona, CA
    I installed new brake shoes right when I got the bike, and have always had the problem.
  7. #7
    crawl779's Avatar
    Apr 2010
    Oh-well, brakes are over rated any way... as long as the throttle works.. then your good to GO...
  8. #8
    dylancordell's Avatar
    Mar 2009
    Georgia,atlanta
    just take them off!! ur bike will be lighter=u going faster!!!!!!!!!!!
  9. #9
    drz63's Avatar
    May 2010
    Corona, CA
    Alright good advice, I already have front brakes, why do I need rear, cant use them have the time because of this problem...haha
  10. #10
    JohnnyB's Avatar
    Nov 2003
    CT
    Have you taken apart the brake panel and cleaned off all of the rust and dirt build up around the pivot arm that goes thru the panel ?
    Just say'n ....
  11. #11
    Cokeham's Avatar
    Oct 2009
    Arlington, Texas
    my back brake used to stick too, messed with the adjustment and sprayed a bunch of lube on the.... well, everything. haha
    works fine now
  12. #12
    jmtracing's Avatar
    May 2008
    Garland, TX
    I am in the same situation
  13. #13
    is TMGP #78
    rob78's Avatar
    Jul 2007
    katy,tx
    when you replaced the brake pads did you replace the little springs too?
    clean all the rust and grime off the drum?
    when that happened to mine I just took it all apart and lubed the shaft that goes into the drum and cleaned it all up and havent had anymore problems.
  14. #14
    drz63's Avatar
    May 2010
    Corona, CA
    Th springs are the only thing have'nt changed</P>
  15. #15
    JackLHyde's Avatar
    Feb 2005
    Germany
    I have this problem with my front brake. It sticks until I brake hard for another time, then it releases itself most of the time. I know for sure I need to replace the brake shoes, though. Do you guys replace the brake springs every time you replace the brake shoes?
klx110 2003 rear drum brake
