Klx 110 Fork Swap
This is a discussion on Klx 110 Fork Swap within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; what forks can you swap for the stock ones? I know the 65s need bigger triple clamps. but what about the 80/85s ive heard the ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By XLr8r
Thread: Klx 110 Fork Swap
    MotoX-67's Avatar
    Jul 2010
    S. Oregon
    Klx 110 Fork Swap
    what forks can you swap for the stock ones? I know the 65s need bigger triple clamps. but what about the 80/85s ive heard the 80s will bolt on???
    Can some one clarify for me which kx/rm forks will fit as a bolt on/ maybe with new front rim and brakes. any help is appreciated.
    Cokeham's Avatar
    Oct 2009
    Arlington, Texas
    Re: Klx 110 Fork Swap
    kx60... for 85 forks, i think you have to have them shorten, need clamps, ect, i would think it'd be the same for kx80 forks too... kx60 forks are the only ones i know for sure that'd bolt up right to your stock clamps.
    is Double Truckin' the Tricky Two
    BaBy!
    XLr8r's Avatar
    Apr 2007
    Muddin'
    Yup, KX60 or RM60. And the stock wheel & brakes work with those forks. You just need a longer brake cable and some heavier springs. And the swingarm/shock to match the raised front end.
    jigggawatt likes this.
    BaBy!
    XLr8r's Avatar
    Apr 2007
    Muddin'
    Here's a link that shows most of the KLX110 suspension options.
    Just close the stoopid pop-ups, the chart is underneath.
    Lots of good info.
    KLX 110 Suspension Chart. Edited by John Falkenthal
    MotoX-67's Avatar
    Jul 2010
    S. Oregon
    Thx cokeham and xlr8r
    Does the overhang from the 60 forks get in the way?
    redirt78's Avatar
    May 2009
    Dry Branch, Georgia.... off in the cut
    ^ they did with mine from time to time, they can drag in deep ruts and sometimes i snagged vines while woods riding.
    if you want some nice forks and not have to spend quite as much money as getting a set of marzocchi's you can get the kx65's. either inverted or the ones that look like a better version of your stock ones. if you get those all you need is the bearing conversion kit that paxracing sells, i think it's $50
    you can find the regular kx65 forks between $200 and $400 and the inverted ones between $400 and $650 depending on what's been done to them as far as valving, springs and whether or not they have had the klx110 stem pressed into them already or if the person is selling them with the pax bearing kit
    the kx65's will have disk brakes too, good ones.
  7. #7
    redirt78's Avatar
    May 2009
    here are a few links
    http://planetminis.com/f68/klx110-fu...ck-156067.html
    http://planetminis.com/f68/06-kx65-f...highlight=kx65
    http://planetminis.com/f68/kx65-fork...highlight=kx65
    http://planetminis.com/f68/marzocchi-forks-157536.html
    http://planetminis.com/f68/get-your-...-a-151474.html
    and pics of the two different style's
    regular ^
    inverted ^ (i think these are off of the kx85 but look about the same)
    and here are some kx60's ^
    and some ktm65's ^
    110 marzocchi's ^
  8. #8
    redirt78's Avatar
    May 2009
klx 110
klx 110 fork
klx 110 fork conversion
klx 110 fork swap
klx 110 forks
klx 110 kx 65 forks
klx110 fork swap
klx110 forks
klx110 kx65 forks
klx110 with kx65 forks
ktm 65 forks on klx110
kx65 forks on klx110
