2005 KLX110 Full Mod punched out & stroked to a 155cc Completely rebuilt from a non-running stock semi-roller in pieces, in boxes, PlanetMinis Members & Vendors, and ebay. Thanx to all!
Firepower's Shaved-Spigot 144 YX Cylinder & Ported YX Big-Valve Race Head Trail Bikes: +5mm Stroker Crank Mikuni 28KO Carburator Pod Filter with Outerwears prefilter Magnetic Oil Drain bolt Ported & Polished Intake with CHP Ported Heat Spacer CHP Billet 2nd Gear CHP Billet Shift Star BBR Forged Output Shaft with 1st Gear OEM Kawi 4th gear Shift Drum Takegawa Quick Shift kit Takegawa Primary Drive Gear Takegawa Polished Clutch Cover for Manual Cable Clutch ADA Racing Black/Polished Billet Engine Cover Kit Barnett RM65/KX65 Clutch Plates & Fibers Sik110''s Heavy Duty Clutch Springs White Brothers/Tokyo Mods Digital CDI Ignition Box Michelin Starcross MS2 Front Tire 2005 KTM 65SX OEM: Front Wheel & Hub with KTM Disk Triple Clamps with PAX Bearing Spacer Kit Forks (with Marzocchi cartridges) black nitride sliders And black anodized uppers valved by FEAL PPR Aluminum Subtanks 2005 KTM 65SX OEM Master Cylinder with ASV C5 Billet Brake Lever Sik-Tendencies 65SX extended stainless steel brake line Works Connection Billet Pro Perch with ASV C5 Billet Clutch Lever Cycra Stealth White Handguards with alloy brackets Scotts Performance rotary steering stabilizer Scotts Performance top barclamp for KTM 200exe Pro Taper Black KLX110 Handlebars with Joker Machine barpad Joker Machine Black Billet Aluminum Case Guard Joker Machine polished aluminum breather filter Renthal full diamond medium firm grips, grey grip donuts T-Bolt/HRC Rear Grab Bar/Fender Brace Two Brothers: Oil Cooler & Diverter Stainless Steel Exhaust Pipe Silencer with red anodized 2" endcap Extended Forged Aluminum Shift Lever Chain Roller 15 tooth polished front sprocket +2.5 Extended Long Travel Aluminum Swingarm - Gen II Race Tech Extended Long Travel Shock with Remote Reservoir Öhlins Racing Reservoir Mounts / Imehdit Delrin brake line guide clamps Imehdit Carbon Fiber Bump Start Cover Cheep Chinese ebay plastics One Industries Snow Camo graphics set SDG Tall Seat CHP Black Billet Aluminum Chain Guide DID 420NZ2 Gold Chain OEM Kawi KX65 Gas Tank modified for KLX110 petcock OEM Kawi KX65 Rear Wheel & Hub Radiant Dynamics 39 tooth hardcoated aluminum rear sprocket Dunlop D756 Rear Tire OEM Kawi KX65 Rear Disk Brake System Sik-Tendencies KX65 rear master cylinder mount Sik-Tendencies KX65 rear caliper carrier BBR Black Aluminum Extended Skid Plate modified to fit with BXM Frame Cradle & HD footpeg mount BXM vented valve cover BBR/IMS Polished ProPegs BBR Polished Forged Aluminum Kick Start Lever BBR Over-the-Top Billet Aluminum Brake Lever Imehdit brake & shift lever savers Outlaw Racing Billet Aluminum Gas Cap Outlaw Racing Reusable Billet Oil Filter
