Sticking Throttle
This is a discussion on Sticking Throttle within the KLX110, DRZ110, TTR90 forums, part of the General Talk category; I have a pwk28 and my throttle gets stuck all the time. I have brand new throttle and brand new cable that slides perfect. Ive ...
Results 1 to 3 of 3
    ONeinthesac's Avatar
    May 2009
    Newfield, NJ
    I have a pwk28 and my throttle gets stuck all the time. I have brand new throttle and brand new cable that slides perfect. Ive had the carb apart there is nothing wrong with the body or the slide everything is smooth and not scratched or galged up or anything, and i also have the heavy spring, it was way worse with the regular spring. I dunno if my motor is drawing to much vacuum that its sucking the slide to hard agains the carb body and it doesnt drop all the way down? All i know is its damn scary when you cant slow down for a turn or coming up to a jump. Has anyone had this problem before and how did you fix it.
    yellow bandit's Avatar
    Oct 2009
    northern cali
    CHECK CABLE ROUTING
    born2ride14's Avatar
    Jun 2010
    JAX FL
    Grease inside of throttle tube? Bent needle?
2011 klx110l throttle sticks
sticking throttle on a klx 110
throttle sticking on drz 110?
throttle sticking on ttr90
